fuel preasure problem
Old Jul 19, 2005 | 09:15 PM
toolmaker's Avatar
It seems that I have a fuel preasure problem but don't know weather its pump or regulator, both have been replaced recently. The problem shows up after driving a while about a hour. If I keep the r's up it runs but lacked on power, doesn't ideal well or for long. When this occurs fuel preasure is down to 20 psi or less, is thier any thing else that could cause this THANKS
Old Jul 19, 2005 | 10:06 PM
Buttercup's Avatar
Re: fuel preasure problem
Voltage drop to the fuel pump?
If you clamp down on the return line does the fuel pressure rise? If not, then I wouldn't expect a problem from the regulator.
If you've got a good pump, regulator, and clean filter I would be inspecting the wiring very closely.
Old Jul 20, 2005 | 03:50 PM
toolmaker's Avatar
Thanks, I'll check the wires and voltage.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
