Fuel odor uncovered!!!
Old Nov 11, 2004 | 11:18 PM
Heatmaker's Avatar
Advanced Member
HA! HA! HA! HA! HA!!!!!!!!
Finally an easy fix...
The fuel odor was comming from the rubber connector on the Fuel line at the Pump housing... for some reason it was squirting out a tad bit of fuel. Went to az and brought some clamps.... Glad I did the trap door method... couldn't have imagined... how much cash I'd a wasted replacing fuel parts...if I didn't cut that hole in my trunk....
Cool
Old Nov 12, 2004 | 05:27 AM
Guest47904's Avatar
Guest
Re: Fuel odor uncovered!!!
I would have thought a leak there would cause a stumbling problem or the very least, a hard starting problem.. Go figure.
Old Nov 12, 2004 | 08:32 AM
Heatmaker's Avatar
Advanced Member
You know... MSD makes a very good ignition kit....
Even when my car should start like crap it never does... even when it has a reason to... even with the burnt out opti... you can never tell....
ANyhow... the leak wasn't bad enough to notice... but I do think it might have had played a role in my bad Fuel pressure problems... after the pump swap...
CaptainObviousI
29
Apr 29, 2021 10:35 PM
4586
Apr 24, 2015 01:03 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
tbyrne
Jul 2, 2002 05:37 PM
