Fuel issue?????
Old Mar 21, 2006 | 12:58 PM
hambone3441's Avatar
Fuel issue?????
Well here is the deal the other day my car died on me coming around a bend at about 20-25mph and would not start back up. I had 1/2 tank of gas at the time. Got it towed home and decided to check the harness from the racetronix kit that has been on the car for about 2.5 years. So I unpluged the harness and plugged the stock harness in and the car fired up fine, then I put the racetronix harness back in and the car still ran fine so I took it out and gave it a wot blast and the car died again. I then plugged the stock harness back in and it started up fine. Today I checked the fuel pressure at idle with the stock harness/racetronix harness and wot on both and had 40plus for pressure all the time. So now I am stumped I thought the harness may be the problem but didnt give me any today. Any thoughts?
Rob
Old Mar 21, 2006 | 02:28 PM
OBE1 95Z28's Avatar
Re: Fuel issue?????
I'd check your ignition system. Are you running an aftermarket ignition box (MSD, Crane)?
Old Mar 21, 2006 | 02:47 PM
Re: Fuel issue?????
delteq
Old Mar 22, 2006 | 05:19 AM
Re: Fuel issue?????
ttt
Old Mar 22, 2006 | 09:57 AM
OBE1 95Z28's Avatar
Re: Fuel issue?????
When it dies do you have dash lights? Do the accessories work (radio, windows, etc)? Ignition switches have been know to be flakey with age and could cause the motor to die.
Old Mar 22, 2006 | 11:29 AM
Re: Fuel issue?????
Not sure....it cranked over but wouldnt start.
Old Mar 22, 2006 | 01:25 PM
97WS6SCharged's Avatar
Re: Fuel issue?????
Plug in the laptop, Rob. Datamaster will tell you if you have any stored codes or whatnot. Has the car been sitting long? I occasionally have the same issue if I let the car sit for a week, but it's fine after a day of driving.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
