Fuel or ignition system?
Old Sep 30, 2005 | 03:41 PM
coray's Avatar
Earlier this week I put gas in my car, it was relatively low when I did this, and about a mile down the road the engine just cut out, I pulled over and it started back up. It did this two more times on the way home. I called and spoke to my dad and he thought it could be the fuel filter. This made sense, since I hadn't replaced it since I got the car. Because I lack the tools, I was not able to just swap it out at that point.
The next day the car was fine, around 60 miles, no problems at all. Then yesterday it was significantly harder than usual to start the car, it would turn over but not start without a few tries. Then, it would not start at all.
We've replaced the fuel filter and the coil, but neither has had any affect. The engine did throw a code earlier in the day but I have no reader to be able to tell exactly what it is.
As far as he can tell it is not getting spark, so I'm wondering if anyone has any areas to examine or insight into the issue.
Old Sep 30, 2005 | 03:52 PM
Re: Fuel or ignition system?
Might want to mention the year of your car, because then we might be able to tell you how to pull the code.
Old Sep 30, 2005 | 04:43 PM
coray's Avatar
It's a 96 z/28
Old Sep 30, 2005 | 07:19 PM
Hawk's Avatar
first thing is first, get is scanned.
You have an autozone near you?? They will scan it for free.
Brian
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Ari G
Dec 11, 2014 03:21 PM
