Header bolt head size
anyone recommend a header bolt that has a smaller head than say what Jeg's sales or what you can buy off the shelf at Advanced auto....
I am having a leak at the #6 primary, I think it is due to the bolt head not really being able to pass the primary and seat on the flange, it feels tight but I think it is a clearance issue.
I had thought about the allen wrench headed ones and I could cut down the head and still be able to wrench it with the allen wrench.
Re: Header bolt head size
What headers are you running? As for header bolts, you can't go wrong with the Brelins. If you have a bit of length left on the bolt, you could try a washer or some type of spacer between the bolt head and the flange. Did you replace the gasket once it leaked? If not, it'll never seal in my experience...
