Fuel filter
It's located under your car, on the drivers side, near the rear tire. It has one line running into it. Just remove bracket, by squeezing it (i think), squeeze the quick connect on both sides, remove one side, then do the same on the other.
One side is quick disconnect (to the right of the word "or" in this diagram) and the other has a tapered nut. You will need a wrench to hold the filter nut and preferably a flare nut wrench for the fitting.
Before you remove the filter, relieve pressure in the lines by depressing the shrader valve on the fuel rail (use a rag to catch the fuel) and pressure in the tank by removing the gas cap.
charchri4
Apr 14, 2015 06:40 PM
