Fuel filter
Old Apr 20, 2003 | 10:39 AM
zuluman13's Avatar
Fuel filter
where is my fuel filter and how do I change also where can i get the filter?
Old Apr 20, 2003 | 11:22 AM
thefast1's Avatar
It's located under your car, on the drivers side, near the rear tire. It has one line running into it. Just remove bracket, by squeezing it (i think), squeeze the quick connect on both sides, remove one side, then do the same on the other.
Old Apr 20, 2003 | 11:36 AM
One side is quick disconnect (to the right of the word "or" in this diagram) and the other has a tapered nut. You will need a wrench to hold the filter nut and preferably a flare nut wrench for the fitting.
Before you remove the filter, relieve pressure in the lines by depressing the shrader valve on the fuel rail (use a rag to catch the fuel) and pressure in the tank by removing the gas cap.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
PCLZ28
Dec 24, 2015 05:19 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
30thZ4C
Dec 26, 2014 05:09 PM
