Found my opti problem. Cam pin way too short! help!
Old Sep 27, 2007 | 12:40 AM
emerica4601's Avatar
Whats up guys,
After installing 5 opti's, i found my problem. I thought my cam pin was too long at first, destroying my optical disc and sensor. Well, i was wrong. My stock pin length from the end of the cam was .615". I took a veneer caliper to the cam pin in their right now, after i took out the opti, and it was .340"!!!!
What do i do? Is there anythign i can do without taking the cam out? Im limited in time!
Help!
Old Sep 27, 2007 | 08:14 AM
Pull out the old pin, put in a new one of the correct length. Should be able to do that with the cam in the engine.
Just curious... how did a "too short" pin damage the Opti? I'm suprised it even engaged the drive.
Old Sep 27, 2007 | 03:58 PM
any idea how hard it is to pull out a cam pin with limited space? you need a special tool thats pretty long. not as easy as you think
Old Sep 28, 2007 | 05:13 AM
Guest47904's Avatar
Guest
Sounds like you might have the wrong cam. What part number is the cam?
Amshnock
14
Jan 18, 2015 11:47 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Decromin
Aug 18, 2002 10:11 AM
HuJass
18
Jun 24, 2002 09:19 PM
