forged internals on a LT1
Old Dec 25, 2003 | 01:55 PM
94TA_LT1's Avatar
When do they become neccessary? forged rods, pistons, crank, ect.
Old Dec 25, 2003 | 07:43 PM
InjectedSS's Avatar
Re: forged internals on a LT1
When you decide to do something MAJOR like a Blower with LOTS of boost, or Nitrous with a BIG SHOT... Or basically when you decide to do a stroker, then it's time to switch...
You can just stay with Standard parts and build a POOSY Stroker. But if you wanna do it right then you should get some FORGED internals
Old Dec 25, 2003 | 07:49 PM
94TA_LT1's Avatar
who makes a good kit with forged internals for a LT1 383 stroker? How big of a nitrous shot can you run with it? Also, i don't know if it matters but i plan on putting AFR LT4 heads on at the same time. Are they any good? Thanks for the help.
Old Dec 25, 2003 | 09:13 PM
InjectedSS's Avatar
Not sure on the AFR's, I know that they are good but I believe some people have mixed opinions on them... You can get PRETTY far on having a stock LT1 head ported out... Or you could pick yourself up some LT4 bare heads and have those ported out which would prolly be the way to go..
As far as stroker KITS.. THey are pretty much GAY... Best thing to do is PIECE it together yourself.. Get some H-Beam Rods, A nice forged crank, some JE/SRP Pistons... Depends on how much you wanna spend really... You can get some EAGLE rods which are EXTREMELY NICE and they are at a reasonable price... Or you could get really crazy and get some Oliver rods which are like a GRAND for a set Kinda overboard to tell you the truth..
hope this helps
Old Dec 25, 2003 | 09:28 PM
94TA_LT1's Avatar
who makes a good crank? thanks for all the help
Old Dec 25, 2003 | 09:59 PM
rskrause's Avatar
Moderator
Callies and Scat, among others, make good cranks, I have had excelent luck with Callies and they are made entirely in the USA. I just ordered a new rotating assy. from them.
A "kit" is a good idea. There is a big advantage unless you know exactly what you are doing to ordering the parts as a "kit" from a knowledgable source. I have seen people make both gross and subtle mistakes ordering parts individually. Everything from rods thsat don't fit the crank journals to pistons with the wrong compression height. And a "kit" will save you money.
One other thing to consider: there are advantages to having the shop doing the machine work order the parts. It's their responsibility to make sure everything fits and if they get the parts there won't be any confusion about who's responsible if something goes wrong. The shop may get a better price than you can as well.
Rich Krause
Old Dec 26, 2003 | 01:48 AM
kmook's Avatar
Advanced Tech Moderator
This topic should be discussed in LT1 Tech-
Transfering.
Thanks.
Old Dec 26, 2003 | 02:29 AM
Antz97ZNJ's Avatar
Id say w/any type of FI
Old Dec 26, 2003 | 05:32 AM
97WS6SCharged's Avatar
Even if you don't get an entirely forged bottom end, it's still a good idea to use forged pistons.
LeftoverChinese
Jan 14, 2024 03:03 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Antz97ZNJ
10
Aug 27, 2002 03:23 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
