Flexpate
Old Oct 5, 2016 | 06:08 PM
frankrizz's Avatar
Flexpate
Gentlemen, I have to replace my flexpate on my 94 lt1. Motor is completely
stock. Not sure what type of flexplate to use. Also want to replace rear main
seal while I am back there. Does the oil pan have to be removed for the seal?
Old Oct 6, 2016 | 10:24 AM
Chimera96's Avatar
Re: Flexpate
you want to run a weighted flex plate vs a neutral aka "zero" balanced flexplate. There will be a small weight tack welded to the flexplate. Basically a stock replacement flex plate.
no need to remove oil pan to replace rear main seal. I use the rubber felPro seal vs the Teflon one
Old Oct 6, 2016 | 11:51 AM
frankrizz's Avatar
Re: Flexpate
Thanks, so much!
Old Oct 6, 2016 | 12:33 PM
Chimera96's Avatar
Re: Flexpate
for example
TCI 399173: SFI-Approved Flexplate Small Block Chevy LT1 | JEGS
note the welded weight on it. you need "external" balance flexplate
Greg88
May 2, 2016 06:38 PM
frankrizz
Nov 21, 2015 05:15 PM
frankrizz
Nov 15, 2015 06:08 PM
frankrizz
Nov 10, 2015 08:06 AM
wbspoon
Sep 19, 2015 08:12 AM
