Feul pressure ?
Old Jun 3, 2006 | 11:42 AM
95WhiteZCamaro's Avatar
Feul pressure ?
I have just put my new aeromotive pressure regulator on and i need to set it what pressure should it be at with the ignition on? and what pressure should it be at when it is running...Stupid me i didnt chech this before i took it off Thanks jason
Old Jun 3, 2006 | 11:45 AM
Re: Feul pressure ?
Stock pressure is 41-47 psi with the vacuum hose to the regulator removed.
Old Jun 3, 2006 | 02:42 PM
97WS6SCharged's Avatar
Re: Feul pressure ?
41-47 with the hose off. 38-41 with the hose on/running. Honestly, you're probably better off returning the regulator and getting your money back though. Their LT1 regulator is junk IMO.
Old Jun 3, 2006 | 05:24 PM
Kevin Blown 95 TA's Avatar
Re: Feul pressure ?
Why do you day that? The only thing wierd about them is that they aren't designed to hold pressure after the ign is turned off, but that is so they can get better flow. I'm very happy with the one I have, and it gives a good boost-referenced signal for a propper pressure rise under boost. It also has a port for the FP gauge sender so you don'g have to run it off the schraeder valve. For a stock fuel line setup, I think they are a good regulator.
Old Jun 3, 2006 | 10:44 PM
Re: Feul pressure ?
We had numerous posts here over the years about the Aeromotive AFPR's failing. I pointed it out, and Aeromotive signed up, and reemed my butt for pointing it out, claiming a Moderator doesn't have a right to do that. In the same post, they admitted they had a bad batch of regulators, and offered a free replacement, no questions asked. Unfortunately, I continue to see repeated posts about problems with the Aeromotive LT1 AFPR.
Take the vacuum line off, and set it as close to 43.5psi as you can get it.
Old Jun 4, 2006 | 06:32 AM
Re: Feul pressure ?
I didn't know that. Do you know what the failure mode was? or what goes bad in them? There's not much inside of there.
Now I got to watch out for my Aero regulator AND my MSD opti. That's just great
Old Jun 4, 2006 | 06:00 PM
Re: Feul pressure ?
I believe they claimed that back in the early 2000's there was a change in pump gasoline formulation that they failed to pick up on, and the elastomers in the regulator were damaged by the new components in the fuel. I can't remember any more than that. The most common problem seems to be the fuel pressure jumping up to about 80psi and not coming down when the adjusting screw is turned.
It does not seem to be as common a problem as it used to be, so maybe they improved things. Most of their products have an excellent reputation, so it seemed odd that they would have so many problems specifically with the LT1 AFPR.
Old Jun 4, 2006 | 11:15 PM
Re: Feul pressure ?
Lol, they jumped on you, Fred?! Like you work for them or something?
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
