Clearance on 383 with big cam?
Old May 30, 2006 | 10:01 AM
Z28sky's Avatar
Quick question my buddy is about to put the gm847 cam in my 383 lt1. I'm running 6 " rods eagle I beams . But he wants to know if the lobes will clearance the rods without a problem with this cam or does he have to clearance them? He clearanced for the crank already.
If anyone has an anwser from experience etc I would appreciate it asap
thanx
-chris
Old May 30, 2006 | 02:00 PM
1racerdude's Avatar
Re: Clearance on 383 with big cam?
Ya will probably need a small base circle cam(.950)
Old May 31, 2006 | 11:35 AM
atljar's Avatar
It hit on a car I did a few years ago (847). It was eagle cast crank , SIR I beams and ross pistons. Had to go in and notch the rod bolts. You want at least .050 clearance
Old May 31, 2006 | 01:14 PM
SStrokerAce's Avatar
Depends on the rods really.... 6" doesn't tell us much.
Bret
Old May 31, 2006 | 03:22 PM
Z28sky's Avatar
SORRY, they are the eagle I-Beam 6" rods. I was told from a few other guys yesterday they had no problem with the this cam and these rods, they didnt have to clearance anything.
Thanx for the info everyone.
I'll double check anyways when I put the cam in.
-chris
Old Jun 3, 2006 | 11:53 AM
Z28sky's Avatar
Cam is in, clearance is fine all good didnt need to do anything.
Old Jun 3, 2006 | 01:44 PM
1racerdude's Avatar
What is the base circle?
Old Jun 4, 2006 | 11:27 PM
streetwarrior96's Avatar
I have a similar question but I'll be using this cam
236/244 duration, .608"/.613", 112lsa
transam_388
Mar 15, 2015 11:53 AM
carl.froehlich
Mar 13, 2015 12:38 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
