fans won't turn on..
Old Feb 26, 2007 | 02:14 PM
red94chicken's Avatar
i got a 94 trans am.. and ever since i have owned it.. 5 months now.. the fans won't turn on.. i have replaced all the sensors, relays, the engine wiring harness and computer. the computer is reading the coolant temp cause i can read it through my scanner and it also shows that its sending power to the relays but the fans don't turn on.. either of them.. but i can make the fans work by using a jumper wire at the relay.
Old Feb 26, 2007 | 02:25 PM
2000GTP's Avatar
Does the temp gauge peg in the red? In stock form, the LT1s run pretty warm from the factory. http://shbox.com/1/4th_gen_tech2.html#cooling
Old Feb 26, 2007 | 06:59 PM
The PCM does not send power to the relays, but it does send a ground to operate them. Do they come on if you jumper the DLC?
Old Feb 26, 2007 | 08:57 PM
it was the fuse.. i am a tard.. i never actually took it out to tested it, just glanced at it frome the side and you couldn't see that it was blown unless it was removed..
Old Feb 26, 2007 | 09:50 PM
JamaroZ's Avatar
That seems the be the same problem I am having in my 96. That link helped a lot, I got to check that tomorrow!
Old Mar 8, 2007 | 03:21 PM
JamaroZ's Avatar
Like i said before I am having that same problem. I have replaced the fuse since I found that it was blown but it keeps blowing the fuse? What do I do know?
Old Mar 8, 2007 | 03:33 PM
2000GTP's Avatar
I would double check the grounds and connectors for starters. Wiring faults can lead to excess current draw which will pop the fuse.
Old Mar 8, 2007 | 04:18 PM
96ZED28's Avatar
I had the same problem with the fuse to the fans always blown, 20 amp? It turned out to be a seized air pump, must be on the same curcuit. Just a heads up, that was my problem. I replaced the air pump, all is good. Hope this helps some.
Colin
Old Mar 9, 2007 | 04:15 PM
Vicious95Z28's Avatar
Colin
Interesting. My fans never run. I recently deleted air and the pump was full of junk. Also my car never runs above about 185 w/160 thermo. Maybe I should check to see if they work.
DirtyDaveW
Dec 1, 2016 05:37 PM
mspennyhughes
Mar 1, 2015 03:50 PM
eazyZ
Mar 1, 2015 07:12 AM
formula79
26
Aug 5, 2002 12:21 PM
