Fans are not turning on.. Help?
I checked my fan motors they are good and replaced the cooling temp sensor. It looks like I'm not getting power to my one fan Relay.When I run a hot wire to the relay and check where the fans plug in it has power. Right now I ran a hot wire from another fan relay but my fans are on all the time when the key is on. It looks like the problem is before the relay box. Any info on what the problem might would help greatly... Thanks
Re: Fans are not turning on.. Help?
I had the same problem but I took the covers off the relay and touch the contacts together and they worked. I thought it was my ECU but it turns out when I changed the thermostat I didn't let the air out of the cooling system. Have you ran it hot lately? Or have you added water to the radiator?
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
