fan wont turn on
Old Oct 19, 2005 | 11:54 AM
ruggerz28's Avatar
fan wont turn on
I dont know why my car is heating up so bad. When ever I sit in traffic, or idle, my car climbs to 240 or so, right up near the red line on the temp gauge, but my highspeed fans won't kick on. I replaced both of the Engine Temp Sensors but I'm still having this problem. I tried to reset the pcm by disconnecting the battery but nothing changed. Any sugestions?
Old Oct 19, 2005 | 12:12 PM
Hotwire's Avatar
Re: fan wont turn on
check the fan relays? fuses? probed w/ circuit tester to see if the fans are getting power?
Old Oct 19, 2005 | 12:17 PM
ruggerz28's Avatar
I know the fans are getting power to them because if i disconnect the sensor that goes to the pcm and get the error code the fan turns on. All the fuses are good how do I check the relays?
Old Oct 19, 2005 | 07:51 PM
Hotwire's Avatar
if you replaced both sensors and the fans aren't kicking on, BUT they do kick on when you disconnect the sensor then the relays are working. why the highs aren't kicking on, I couldn't tell you. i know the 94 fans use three relays to run the fans, but if one relay goes dead, it kind of kills the system.. about the only other info i could offer is to find someone w/ autotap type scanner and try to figure out why they aren't working. I know someone w/ a tech 2 can tell the ecm to turn the fans on, but only technicians have access to them.
good luck.
Old Oct 19, 2005 | 10:00 PM
On my site, you can find cooling system and testing info.
Old Oct 20, 2005 | 06:24 AM
Hotwire's Avatar
Talking Re: fan wont turn on
said it before and I'll say it again, Rob, , you da man!
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
