fan problems
Old Jun 21, 2003 | 08:12 PM
94z28blue's Avatar
fan problems
i just changed my waterpump, started the car, the fans came on right and car was sitting at perfect temp, i turned it off, when i turned it back on again about 5-10 min later it got hot and the fans were not coming on, when driving the temp is down but when in residential or at a long stop light, etc. the temp goes up, anyone know why the fans are not turning on or what i can do to check them. thanks
Old Jun 21, 2003 | 08:36 PM
Check the obvious first-fuses. Also be sure you have bled any air out of the system so there are no pockets that might be fooling the temp sensor in the water pump.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
MattFick
Feb 15, 2015 10:16 PM
slothgrant
Aug 22, 2002 03:01 PM
