famous high idle
Old Apr 25, 2009 | 11:18 AM
maybe2fast's Avatar
famous high idle
Runs great, just idles high.
just replaced the intake and drivers side header gasket. Idles at like 2000k, but if you blip the throttle it will idle down to like 1000k. Thinking it is the injector O-rings leaking vacuum, but I did also remove the TB and clean the IACs head and reinstall. No SES light.
Going to to the IAC relearn tonight, was fine before the repairs
Old Apr 25, 2009 | 12:33 PM
brianswimmer23's Avatar
yea but most of the time whenever you pull off the IAC especially after a while(if you have never changed it) it could get out of whack depending on how old it is. im sure you will need a new one. their only 30 bucks. at least go with that so its not a major fix and major price to fix.
Old Apr 25, 2009 | 10:12 PM
user 647483's Avatar
Did you plug the brake booster vac line back in?
(And all of the other vac lines to the TB?)
Old Apr 28, 2009 | 10:49 AM
maybe2fast's Avatar
well with the suggestion of an IAC motor, I did the cardinal sin...took the IAC off and pulled gently on the head out alittle. Reinstalled it and went through the relearn.
All is well
Old Apr 29, 2009 | 10:48 PM
94 Assault z28's Avatar
your timing is too high take it down a few degrees
Old Apr 30, 2009 | 12:38 AM
porksoda's Avatar
Check the voltage off the TPS.
Old Apr 30, 2009 | 12:41 AM
MikeGyver's Avatar
Old Apr 30, 2009 | 05:09 AM
All is well
If I'm reading this correctly.... he solved the problem 4 posts ago.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
