Failed emissions today..
Old Jul 11, 2006 | 12:37 PM
chesee48's Avatar
So i basically drive the camaro once every other month now that i live and work in the city. The car sits at home in Bartlett and it was due for emissions. I drove it for about 30 min ( also on the way to the test got a speeding ticket and a ticket for not a valid insurance card) and then took the test. I failed the HC- Hydrocarbons by plenty. I think the standard was .80. Mine read 2.50....
i was told that its basiaclly unburnt fuel. Would running and driving the car do anything to make my HC that much lower in order to pass?
Old Jul 11, 2006 | 02:58 PM
OBE1 95Z28's Avatar
Re: Failed emissions today..
A hot cat will help you pass. Typical things to put your best foot forward is a good tune (fresh spark plugs, wires, clean air filter, fuel filter), fresh oil change, O2 sensors if yours have been abused or greater than 50K miles on them. How many miles on the car?
Old Jul 11, 2006 | 03:18 PM
user 647483's Avatar
That sucks man
You running with or without smog equipment?
Old Oct 11, 2006 | 03:39 PM
chesee48's Avatar
car failed again worse then before....any one have any ideas?
Old Oct 11, 2006 | 03:51 PM
96TurboTA's Avatar
Replace the cat
Old Oct 11, 2006 | 05:11 PM
What did the CO and NOx look like.... test results vs. pass limit?
Old Oct 11, 2006 | 05:20 PM
reamo04's Avatar
well, you better just give up and sell the car to my brother for dirt cheap since he's looking for a LT1.
On a more serious note, try getting some injector cleaner and running that through, Replace your spark plugs. Anything that will help your fuel system, do it.
Old Oct 12, 2006 | 12:17 PM
chesee48's Avatar
i dont have the numbers with me, but i know the CO was almost half the amt of the limit.....i'll get the exact numbers asap...
Old Oct 12, 2006 | 12:52 PM
TobyZ28's Avatar
I'm failing on HC too. I have a friend who was failing on HC and couldn't figure out why. It turns out that the charcoal canister was leaking and needed to be replaced. What was happening was that the unburnt fuel was leaking out and getting sucked into the machine causing high HC.
Old Oct 12, 2006 | 12:56 PM
chesee48's Avatar
do you have a part number on that?
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Boss002
Jul 24, 2015 10:47 AM
