Factory Oil Cooler
Old Dec 4, 2005 | 11:15 PM
  #16
JoeliusZ28's Avatar
Re: Factory Oil Cooler
interesting... is it easy to retrofit a 94 onto a 95? or should i just delete mine? are there any aftermarket options?
Old Dec 5, 2005 | 07:37 AM
  #17
Swapping should be just a matter of bolting it up.
Aftermarket coolers are of a different design and don't use coolant as the cooling medium. They are more like a small radiator that you would have plumb and mount somewhere. More efficient for cooling, IMO.
Old Dec 5, 2005 | 10:10 AM
  #18
JoeliusZ28's Avatar
who would make one of those? I did a brief search on summit and couldnt find anything.
Old Dec 5, 2005 | 10:53 AM
  #19
Perma-Cool makes oil coolers. Summit sells them. Vendor code for Perma-Cool is "PRM".... typical part #s:
PRM-10189, 40189, 10195, 69195, etc.
Old Dec 5, 2005 | 11:09 AM
  #20
JoeliusZ28's Avatar
awesome, thanks
Old Dec 5, 2005 | 12:20 PM
  #21
OBE1 95Z28's Avatar
Anybody know the P/N for the 93-94 style oil cooler?
Old Dec 5, 2005 | 01:23 PM
  #22
Z28barnett's Avatar
I have an '95 with a factory oil cooler.
At 96k miles I have had no problems with it.
Even the external oil to air radiator type can plug and are a flow restriction.
The Oil to water factory type are lighter, thermostat controlled and can not be damaged by junk on the road.
If either type plugs, you will risk engine damage, no arugument there.
I am a little puzzled about how the factory filter is supposed to plug since oil flowing through it has already been through the oil fliter.
Unless oil can bypass the filter, some can not sure about the LT1, you should be ok with good oil.
I added the oil to water power steering cooler to my car and have had zero problems with that also.
You want your oil hot, but not too hot. That is why the oil/water is good. Its goal is to keep the oil under 300 degrees or so. Don't need the oil to be cooler than the water.
Judgment call, but I would leave the factory oil cooler on the car.
Z28
Old Dec 5, 2005 | 01:41 PM
  #23
JohnD's Avatar
Wait a minute. In a Chevrolet, the oil filter bypass is in the block ahead of the filter and the oil cooler is between the block and the filter. Even if the oil cooler or filter is completely blocked, the engine will not starve for oil, it just won't get filtered oil. I can't see how it would be blocked anyway unless pieces of metal are circulating in the oil system and that is a result, not a cause.
Old Dec 5, 2005 | 02:31 PM
  #24
OBE1 95Z28's Avatar
Engines that have been opened up are prone to RTV, gasket material and general dirt being dropped inside that can make their way down to the oil cooler screen.
Old Dec 5, 2005 | 05:07 PM
  #25
Scotts94z28's Avatar
220,000 miles on my 94, been my daily driver for over eleven years now. No problems with my oil cooler.
Old Feb 10, 2007 | 09:52 AM
  #26
94/96ZsM6s's Avatar
no problems with mine at all on my 94z and it has almost 100k on it and i just cleaned it up before putting it back on my 396. i need to put a oil temp sensor in my canton pan and see what temp the oil is at...and compare to my stock 96 W/O the oil cooler.
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
blkWidow
Apr 20, 2015 09:27 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
cmdeshon
Dec 12, 2014 10:51 PM
97 RedSS
Jun 10, 2003 07:58 PM
