!evap
Old Aug 23, 2007 | 07:42 PM
dangalla's Avatar
!evap
so..... when i was putting my motor together i was in such a rush that i completely forgot to put the evap stuff back on and when i took it to work to install the motor i did not have the evap stuff with me when i realized what i had done
so i just plugged the hose that comes to the engine compartment
my question is will i have any problems from not running said equipment, i have 250 miles on the build as of right now and i have no codes and no problems as of yet
Old Aug 24, 2007 | 08:04 AM
Surprising its not setting codes for the missing EVAP solenoid and the missing vacuum detection switch. No other problems with the engine from removing EVAP, but it might tend to smell of fuel at the rear of the car. Make sure there is a vent to relieve pressure from the tank. Hopefully, you also put a vacuum cap on the nipple on the side of the throttle body.
Old Aug 24, 2007 | 08:36 AM
wrd1972's Avatar
What he said.
I started to delete my entire system when the vacuum line got clogged with charcoal, I decided to clean the line and replace the canister to avoid the gassy smell.
Old Aug 24, 2007 | 09:18 AM
dangalla's Avatar
Originally Posted by Injuneer
Surprising its not setting codes for the missing EVAP solenoid and the missing vacuum detection switch.Hopefully, you also put a vacuum cap on the nipple on the side of the throttle body.
yeah i capped the throttle body, but i am also really suprised that it did not give me a code, i scanned it yesterday and all i got was an o2 sensor code
Old Aug 24, 2007 | 09:51 AM
Don 97 SS's Avatar
That is interesting. Is there any relationship between the evap system and the O2 system (i.e. wiring) that could cause this? I thought the ODII you have would set a DTC if you ran minus the evap system.
Old Aug 24, 2007 | 10:46 AM
There is no wiring for the EVAP system that is common to the O2's.
Old Aug 24, 2007 | 10:52 AM
White96Z28's Avatar
That's strange. My car throws a code for evap since the vacuum detection sensor is missing. That code actually comes almost immediately, like within 10 minutes after a hard reset.
Old Aug 24, 2007 | 10:55 AM
dangalla's Avatar
thats what i would have assumed, i planned on just driving it home with the light on and installing the evap crap there, but like i said before i currently have 260 miles on the build with no codes, weird to say the least, i even called the tuner to be sure he did not tune out the evap system the only thing i can think of is not enough drive cycles
Maybe he doesn't have enough "drive cycles" on it, with only 250 miles.
MDZ28
11
Sep 24, 2015 09:15 AM
MDZ28
Sep 7, 2015 09:16 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
