Evap
Old Jul 15, 2004 | 12:08 AM
simple's Avatar
Evap
what can i do to get rid of it?
i'm throwing a code right now for it PO441 or something like that
i've heard i can get rid of everything down to where it comes out of the fender and block it off at that point and then drill a small 1/16" hole into the gas cap to compensate....
any other ways to go about this?
Old Jul 15, 2004 | 12:13 AM
P0441 Evaporative Emissions (EVAP) system no flow (during purge)
Could be a simple case of the line being plugged with carbon, the solenoid plugged, or sticking closed, a leak in the vacuum line from the TB to the purge solenoid or a faulty flow sensor switch. Fixing it wouldn't be a bad idea. You will get a lot of fuel smell in the back around the fuel tank without the purge system.
Old Jul 15, 2004 | 12:17 AM
simple's Avatar
yeah the gas smell was the reason i asked if there was another way to eliminate it without getting the stench
flow sensor switch, where is that located?
the solenoid is located on the passenger side of the manifold right? atleast on my '97 neway
thanks Fred
Old Jul 15, 2004 | 07:57 AM
Flow switch #11 .
Old Jul 15, 2004 | 01:20 PM
simple's Avatar
thanks Rob.
where is the solenoid located then?
Old Jul 15, 2004 | 01:47 PM
Originally posted by simple
thanks Rob.
Its #7 in the same diagram.
simple's Avatar
tis what i thought
thank you
MDZ28
11
Sep 24, 2015 09:15 AM
MDZ28
Sep 7, 2015 09:16 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
