error code 33 map high
Old Aug 14, 2005 | 08:01 PM
93redlt1's Avatar
does this mean my map sensor is shot or is there a possibility that a vaccuum leak is present.
Old Aug 14, 2005 | 10:57 PM
Re: error code 33 map high
Depends.... the code sets when MAP at idle excedes 68kPa. With a stock cam, you would need a huge vacuum leak to have MAP increase from the typical 30-35kPa at idle to 68kPa. However, with an agressive cam, you can see that high a MAP reading = low vacuum. You don't mention if you have any mods, cam, etc., so its hard to answer accurately. Adding a "signature" with info about your mods will help people give you a more accurate answer.
Could also result from incorrectly adjusted valves, excessive misfires, etc.
Could also be a loose connector. The MAP sensor connectors dry out and crumble, giving erratic MAP readings, which can trigger the code. I'd check that first.
Old Aug 14, 2005 | 11:05 PM
Unexpected dying of the engine can also trigger a map code in some cases. The MAP sensor is not the cause, but the MAP code is a result of other factors. In that case, clear the code and see if it returns.
DirtyDaveW
Dec 1, 2016 05:37 PM
lt1matt
Mar 21, 2015 07:35 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
91Bird305
Aug 5, 2002 01:39 PM
