Engine swap
Old Mar 26, 2012 | 12:01 AM
jloshotz's Avatar
Engine swap
Looking to see if anyone knows I I will run into any trouble installing a 96 Camaro LT1 into my 95. Pretty sure I would have to swap timing covers, and probably swap my knock sensor over, but aside from that, would there be any other pitfalls?
Old Mar 26, 2012 | 12:36 AM
Rob94hawk's Avatar
Re: Engine swap
IIRC, the crank hub on a 96 is shorter because of the crankshaft position sensor.
Old Mar 26, 2012 | 12:42 AM
jloshotz's Avatar
Okay, crank hub too, thanks Rob!
Old Mar 26, 2012 | 05:21 AM
Re: Engine swap
There is no need to delete the CKP sensor or change the timing cover or the crank hub. Just leave it all alone, and don't plug in the CKP sensor, since there is nothing to plug it into. You'll have the vacuum detector for the EVAP system, and that doesn't get plugged into anything on your 95 either. That can be deleted because its another eyesore.
Old Mar 26, 2012 | 07:04 AM
jloshotz's Avatar
Thanks Fred, sounding better already, less work
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
