Engine Swap
Old Jun 22, 2009 | 08:35 AM
1Wicked_Z28's Avatar
Engine Swap
I got a 94 Z28 and the motor took a poo poo on me. i am lookin at gettin something done soon. I found a guy who has a 95 Buick Roadmaster with the Lt1 with about 90k on it. now if i am right everything will work for a swap. just take my heads and motor mounts and it should work?
Old Jun 22, 2009 | 09:00 AM
bw_hunter's Avatar
The front cover and timing set are different. Your 94 OPTI won't work with it. CAm is different with less lift and duration. The physical mounting points are identical and a swap will certainly be easy....
Old Jun 22, 2009 | 09:17 AM
so if i swap them few parts off mine it will be all work then cuz i have a bigger cam that i am gonna put in anyways.
Old Jun 22, 2009 | 09:19 AM
bw_hunter's Avatar
Yes, it'll all work. Actually, if the new engine comes with the OPTI in place, go with the newer setup. The vented system lasts longer and is cheaper to replace when it fails.
Old Jun 22, 2009 | 09:45 AM
if i left it the way it was and just did my heads and intake is the wiring all gonna stay the same them for the pcm.
Old Jun 22, 2009 | 09:46 AM
bw_hunter's Avatar
Yes....
Old Jun 22, 2009 | 12:10 PM
96capricemgr's Avatar
I would leave the b-body heads on it and save your's for when you have the time money and inclination to port them. They are a bit lift limiting though so you will have to check and see if they will accomodate your cam choice.
Intake manifold vary by year not model car, 94-95 are going to be functionally the same if not the exact same piece.
In bolton form the b-body and f-body make very similar peak numbers, I actually wonder if it was not the f-body cam that was the compromised one, compromised to kill a little very lowend torque to save your POS axle. Not a big deal since you want to swap the cam anyway.
Old Jun 22, 2009 | 01:46 PM
my next question is with the transmission out of that car will it work in mine cuz i wanted to swap them out and send mine in and get it built since mine is a little weak
Old Jun 22, 2009 | 04:03 PM
The tailshaft housings are different b-body to f-body, that is an EASY swap.
screwy thing is there are small year based differences all the way through the LT1 years, something meaningful changed every year from 93-96 at least.
You can make the 95 tranny work but you will have to talk to more of a tranny guru. The big difference is the 95 tranny is Pulse Width Modulated and the 94 is not. I believe you can modify something in the pan and negate this difference but like I said you need a tranny guru to tell you waht it is.
Old Jun 22, 2009 | 04:53 PM
Counted Out's Avatar
I'd look for something with less mileage personally. 90K is alot and you don't want to be doing this all again soon do you?
Old Jun 22, 2009 | 05:38 PM
reamo04's Avatar
why not go through one of our sponsors, theres one that was selling lt1 engines for 999
Old Jun 23, 2009 | 03:54 AM
bw_hunter's Avatar
LOL...90K is not a lot for these engines......
Old Jun 23, 2009 | 08:43 AM
That Camaro Guy's Avatar
94 tranny uses a "on/off" command from the PCM to lock up the converter, the 95s need a different command for the converter to lock. You can run a 95 tranny in a 94 car, but you need a 95 .bin file loaded to the computer to work right. This is all under the assumption that the roadmaster's transmissions follow the same pattern of the F-bodies, I could be wrong but it's an educated guess.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
