Engine Missing
Old May 30, 2003 | 08:18 PM
Lyle A's Avatar
Engine Missing
Some one stole my engine....... No, not really..........It was running fine this morning. It is a rather warm day and I had to sit in some traffic. It didn't over heat but my idle started to act funny. It would jump real fast to about 1200. If I held the gas a little it would stop.I was at another light leaving town and there was a honda ricer in front of me. He cut me off actually. I was hoping to smoke his *** but my car let me down. It was surging or bucking when I punched it and in the high rpm range it was backfiring out the intake. I had to play it like I didn't want to race. Shameful I tell ya. This happened suddenly and it looks like it aint goin away easy. Any Ideas? Please don't tell me its the opti. I'm in a poor situation right now. My car has 66,000 miles on it so I figure it gonna need something. All suggestions will be greatly appreciated and investigated. Also, it isn't as bad when the temp is below 200.
Old May 30, 2003 | 08:46 PM
n2ceptor's Avatar
check the ignition system for loose wires/connections.... also it might be a sticking EGR valve.... Possibly the fuel filter..... when was the last tune up???? ETC.. My eng runs around 185-190 ..... Buit I do run a 160 degree thermostat...
Old May 30, 2003 | 08:59 PM
Lyle A's Avatar
I just got the car in December and it has been running good. I'm sure it's time for tune up but what does that involve? Just plugs and wires right? How do I test the EGR valve?
Old May 30, 2003 | 11:46 PM
95z115's Avatar
Yeah I would say check the plugs or the ignition wires, it also could be the EGR valve, however it the EGR valve is bad, your check engine soon light should go on.
Old May 31, 2003 | 10:03 AM
certifiedlt1's Avatar
one easy thing to try is to simply clean ur throttle body out and then take ur iac out and clean that up a bit too. just a suggestion
Old May 31, 2003 | 10:09 AM
Lyle A's Avatar
Thanks, I'll try that too.
Old May 31, 2003 | 10:10 AM
jgonzales's Avatar
mine started doing pretty much the same thing about 3 or 4 days before the opti went out. check the other stuff, and just give it a few days to see if it goes out.
Old May 31, 2003 | 10:26 AM
Lyle A's Avatar
That's what I didn't want to hear. But It's what I thought also. I have to pay someone to do it for me because I don't have a place to tear my car apart like that. Oh, well such is life.
Old May 31, 2003 | 10:37 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
damnit.. thats the only reason i came in...
and YOU ruined it...
Old May 31, 2003 | 10:47 AM
Lyle A's Avatar
You have the same problem? I'm going to a shop a get a diagnostic test done, then go from there.
Old May 31, 2003 | 10:50 AM
frmula1's Avatar
no, im saying the only reason i came into the thread was to provide you with some smartass response like
"well, go find it..."
but you stole my outlet to do so by dismissing it in your first sentence
Old May 31, 2003 | 10:52 AM
Lyle A's Avatar
LOl. I see how you are. Well, I'm glad you don't have this problem cuz it sucks.
Old May 31, 2003 | 10:53 AM
frmula1's Avatar
sell it and get a 502
Old May 31, 2003 | 11:21 AM
ghostle's Avatar
Mine acted the same way for weeks before setting off code 16. It was my opticrap. I`ve heard of prices around $1200 for this change. There is a lot of labor to it but can be done yourself if you had somewhere to do it. About 6 hours of labor.
Old May 31, 2003 | 05:17 PM
Lyle A's Avatar
I took it to a friends shop today and we put a scanner on it. Got a code 44 which is left O2 sensor lean. I replaced the fuel filter and both O2 sensors. The right side is a bitch. I had to drop the starter and exhaust to make room for a wrench. After all that the code cleared. I took it out and drove it real hard. It seemed to run pretty good except for the idle dropping to 500 at times( which it has since I got the car) and a little miss at 4000 RPM with wide open throttle. I ordered some new wires and bought plugs but after fighting that sensor for hours I will wait a while for those items or pay someone to do it. I will have to drive it some more to see if that fixed it. Now, Where's that honda that cut me off yesterday?I took it to a friends shop today and we put a scanner on it. Got a code 44 which is left O2 sensor lean. I replaced the fuel filter and both O2 sensors. The right side is a bitch. I had to drop the starter and exhaust to make room for a wrench. After all that the code cleared. I took it out and drove it real hard. It seemed to run pretty good except for the idle dropping to 500 at times( which it has since I got the car) and a little miss at 4000 RPM with wide open throttle. I ordered some new wires and bought plugs but after fighting that sensor for hours I will wait a while for those items or pay someone to do it. I will have to drive it some more to see if that fixed it. I hope it is. Now, Where's that honda that cut me off yesterday?
armedtrigger
Feb 24, 2015 08:30 PM
DetroitZ28
Feb 13, 2015 07:33 AM
cmdeshon
Dec 12, 2014 10:51 PM
dmaastr
9
Jul 1, 2002 02:22 PM
