Emission Help
Old Sep 12, 2008 | 12:11 AM
  #31
bowtiekid's Avatar
So I need a new pcm is pretty much what your saying?
Old Sep 12, 2008 | 05:21 AM
  #32
No. Not sure how you came to that conclusion. I suggested you might have problems with the grounds for the PCM and engine. The PCM seldom is the problem. You also have the other code problems you need to sort out. Those point to electrical problems as well.
Old Sep 12, 2008 | 07:10 AM
  #33
I think I would clear the codes, start over and see what comes back. So much work has been done, who knows when these things occurred or what is still active?
Old Sep 12, 2008 | 08:47 AM
  #34
bowtiekid's Avatar
Alrighty.
Ill pull the pcm fuse today and let it sit out then put it back in and see what I get.
Ill add more grounds if I need to and make sure everything is up to par again and hopefully the SES light wont return
Old Sep 12, 2008 | 09:18 AM
  #35
bowtiekid's Avatar
Its not even worth fixing it.
Ive already dumped eh, close to 10k into this car and its still has problems, Im a kid with a low budget and this car needs to go
Old Oct 1, 2008 | 12:55 AM
  #36
bowtiekid's Avatar
Figured out I dont have money to get a different car. I dont think things through very well.
Ok since then., I pulled the engine harness and found a few things, Red alternator wiring, frayed at the connector, connector fell off upon looking over the harness.
All other connections fine.. I do have 3 pink wires soldered in a connection into 1 wire for the injectors? Im guessing its right.
Im going to replace the MAP connector, Alternator and VSS connectors and throw it back on and see what it does. Also Going to add another PCM ground.. But where? Because obviously grounding it on the Passenger fenderwell isnt working.
-Mark
Old Oct 1, 2008 | 05:21 AM
  #37
The pink wires are just +12V, constant. #1/4/6/7 should be supplied by a single pink wire from fuse #10 and #2/3/5/8 by a single wire from fuse #9. Are you saying someone repaired or altered the factory wiring?
Old Oct 1, 2008 | 09:40 PM
  #38
bowtiekid's Avatar
It was repaired, but by a shop. Doesnt seem to be altered in any way.
The shop did add a ground, they tapped into the tan / white wire ( coil grnd wires ) and soldered a wire to that then grounded it with the ABS wires? It was on the passenger side fenderwell?
Is that a legitament repair? Or should I take that ground out?
Old Oct 2, 2008 | 06:13 PM
  #39
bowtiekid's Avatar
I think the reason why my volt gauge was jumping around was because of the red wire.
Or am I wrong? Replacing the connectors when I get them and putting the harness back in.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
