electric fans only turn by diagnostic plug
Old Feb 16, 2011 | 09:26 PM
grabbem88's Avatar
well after thinking i had everything fixed i seen smoke from the front of car and noticed that the temp was climbing pretty quick so i shut car off and turned key back on to activate fans..when i heard no fans i instantly put my jumper wire back on diagnostic plug to activate them..since i knew fans worked from fooling with codes and such.
i checked all relays and pulled them one at a time and they killed each fan wired to said relay..
fuses were good
the project i did today was fix cut wires to ect pig tail..i know it works since the code is gone.
i just bought car a week ago and with weather i never checked fans plus the temp gauge was shot aswell..
i read all of the shbox schematics and from what i checked i'm not sure where else to look?...
iknow car has straight water in it..and a/c is removed..so what's my next direction?..
Old Feb 17, 2011 | 05:52 PM
grabbem88's Avatar
Re: electric fans only turn by diagnostic plug
nevermind
i just spliced into the blue and green wire and grounded to frame..all is good now
mspennyhughes
Mar 1, 2015 03:50 PM
squarehead
Jan 15, 2015 07:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
