1995 camaro exahust problem
Old Feb 12, 2011 | 03:11 PM
chris_14kingz28's Avatar
I have and 1995 z28 camaro i just got done installing pacetter longtube headers. with and ORYP . i get the car back and the car is alot weaker with the headers. is it bc of that i have no catlatic coverter? with the back pressure and all?
Old Feb 12, 2011 | 05:49 PM
Slick-Z's Avatar
Re: 1995 camaro exahust problem
If the engine is stock then you should go no bigger than 1 5/8 headers if you have the 1 3/4 inch headers then you will hardly get any back pressure at all. This is a common problem just wondering if this is the setup you have due to you not giving that much info. Also from 95 to 96 they went from single cats to dual so if you have no cat and three inch piping diameter or smaller then theres no problem. But you cant go more than 1 5/8 headers and 3in piping or you will have alot of blow buy exhaust with no buildup for back pressure. So good luck buddy.
Old Feb 12, 2011 | 06:54 PM
bw_hunter's Avatar
Sorry, this just isn't right. You can easily run 1-3/4" headers on a stock engine. All that back pressure stuff I'd pure fairy tale. Blow by is from combustion gases passing by the rings and has nothing to do with the exhaust system
Old Feb 12, 2011 | 07:45 PM
the cars exahust is pasesetter longtube 1-3/4" to 3 in oryp goin in to and slp loudmouth 2 muffler. the car also has a bbk 52mm throttle body and 373 gear. the car is just not performing any better actually worse on performance with the longtube headers. the car had plenty of power befor and now its weaker. i dont understand it
Old Feb 12, 2011 | 09:19 PM
The problem with large diameter primaries on a stock engine is not due to "back pressure". The problem is that the large diameter slows down the gas flow in the primary, which reduces scavenging at low engine loads, and may cause severe reversion, with exhaust gasses flowing back into the cylinder.
"Back pressure" is a myth, and you will not lose torque from reduced back pressure. But you may have issues with scavenging and reversion at low engine loads with oversize primaries. That's one of the reasons "step" primaries can be attractive.
ACE1252's Avatar
Are you absolutely sure that you don't have any exhaust leaks?
Old Feb 12, 2011 | 11:39 PM
1badasZ's Avatar
make sure you havent burned any plug wires. been there n done that a few times
Old Feb 13, 2011 | 06:02 AM
yes the car has little exhaust leaks but they verry little. and when we put the headers on we changed the spark plugs just with basic (auto lites) it there a different plug i should run on my car? and all the wires are tied away from the headers.
Old Feb 13, 2011 | 07:30 AM
jlew69's Avatar
I just put long tubes on my 95 Z w/loudmouth 2 with no cats. My headers are 1 5/8 w/ 3" y-pipe into the 2 1/2" exhaust. I do have a larger cam. My car picked up. I used NGK plugs. Only thing with my car after the install, I smell more exhaust gas. NGK plugs are great for me, I use them in my 1000 HP 69SS.
Old Feb 13, 2011 | 07:42 AM
i just dont understand how i could lose hp from putting headers on like it is a varry big differance losing power wise. could it be that i need and cat?
Old Feb 13, 2011 | 07:48 AM
lt1-xjs's Avatar
Fix the exhaust leaks first.
Old Feb 13, 2011 | 08:14 AM
bw_hunter's Avatar
Fix the leaks x2. If the leak is ahead of the oxygen sensors the engine thinks it is leaner than it is. Then it adds fuel and the car runs poorly.
Old Feb 13, 2011 | 08:18 AM
all the leaks are after the oxygen sensor.
Old Feb 13, 2011 | 08:22 AM
bw_hunter's Avatar
If they are near the sensor even after it you can have similar issues. Fix anything close.
Old Feb 13, 2011 | 08:26 AM
thanks guys i will fix all the leaks then i will let you guys know what happend thanks
