Electric Cutout Installed
Old Sep 18, 2005 | 09:28 PM
  #16
boyd's Avatar
Re: Electric Cutout Installed
I have a QTP electric cutout and mine is located right in front of the rear axle.
This way the cutout goes over speedbumps at the same rate the rear tires are traveling over the speedbumbs (no drag problem, this way) .
I also was not crazy about the toggle switch that came with the cutout so I went to my local parts store and purchased a (on-off-on) rocker swith that resembles a rear window switch for a 4Runner or K5 blazer. Just tape up the two leads at either end on the toggle switch ( this gives power for the red/green LED lights) the rest is copy from one switch to the other.
I have a 94 Z and it fit well under the ciglighter by cutting out the panel .cutout switch
I found on mine that if I get a little leak, all I need to do is bump the switch and it will close fine. The problem is when you release the switch, the plate that closes will back off just a tad. If you bump the switch when it is closed, it will insure a tight fit.
Just my .02 and hope this helps.
Old Sep 18, 2005 | 09:41 PM
  #17
transamdude95's Avatar
Nice location for the switch. Mine is out of sight in the ash tray holder. It is perfectly placed, I can very easily switch on/off the cutout. I'll get a picture up as soon as I can.
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
stanghunter211
Aug 29, 2002 03:04 AM
Rich_z28
Aug 27, 2002 12:20 AM
