Easy way to R&R Radiator?
Old Aug 3, 2019 | 04:47 PM
chevykid's Avatar
Anyone have an easy way To R&R the Radiator on a '95 Camaro Z28 Auto, A/C without taking the A/C Condenser out?
Old Aug 3, 2019 | 09:24 PM
Re: Easy way to R&R Radiator?
You don't have to remove the condenser, just unhook it from the radiator. Below is from my cam removal guide.
  • Remove all hoses to the radiator.
  • Remove the radiator cover. (three 8mm bolts on top)
  • Disconnect and remove fan assembly. The fan assembly is hooked to the radiator side tanks and can be lifted up to unhook it and then lowered out the bottom.
  • Disconnect the transmission oil cooler lines from the radiator (if applicable). (1/2" fitting - flare nut wrench recommended) A small amount of transmission fluid will come out. I used a couple of plastic plugs I had to cork the transmission line fittings in the radiator, so that it would not drip as I removed the radiator.
  • Unplug low coolant sensor connector.
  • Release a/c condenser line from guide on bottom passenger side of radiator tank.
  • Lift up on a/c condenser to unhook it from the radiator. Remove the radiator by pulling it up out of the lower saddles. Try not to damage the fins.
Old Aug 4, 2019 | 01:36 PM
chevykid's Avatar
Thanks! This is what was stopping me.
bowtiepwr
Aug 19, 2006 08:32 AM
deadmeat2004
May 17, 2006 10:16 PM
ibanez6rg
Dec 29, 2003 01:21 PM
CJ Black LS1 Z28 M6
Oct 31, 2003 11:07 AM
madwolf
Jul 23, 2003 11:47 PM
