walk through on radiator change
Old May 16, 2006 | 09:27 AM
deadmeat2004's Avatar
Is there a site with the basic walkthrough on how to change the radiator on a 96 SS? (or if it could be explained, want to make sure i dont screw up anything) i didnt see anything when i did a search. thanks guys.
Old May 16, 2006 | 11:01 AM
jsetzer's Avatar
Re: walk through on radiator change
Where abouts in OK are you? I may can help you out. I'm in Norman.
Basically once you pull the cover off the top (3 screws) its pretty easy.
Drain the coolant,
Unhook all the hoses going to the radiator
unplug fans
pull fans (prob easier out the bottom)
pull radiator, be careful with your AC condensor though, they are sandwitched together
Reinstall.
Got a leak? Mine is like a sponge and I need to find a replacement. As long as it stays cool its fine, but if it gets hot and builds pressure it will spray out of the plastic endcaps.
Old May 16, 2006 | 12:12 PM
rhummer37's Avatar
The hardest part is getting that A/C condensor separated without bending those aluminum?? lines- basically the condensor has plastic hooks going down which rest in plastic hooks on the radiator which go up, so you have to lift the consensor up while pulling the radiator down to separate them.
Does anyone know of an after-market radiator that will still have the brackets to hold up the A/C condensor?
Old May 16, 2006 | 12:31 PM
rhummer37's Avatar
Also, at the bottom of the passenger-side of the radiator, there is a maybe 1/4-inch plastic hook semi-supporting another ?aluminum?? A/C line. You may be able to get the radiator out without cutting this plastic hook, but since you-like I- was replacing the radiator, you will probably want to cut it- without knicking the A/C line.
Old May 16, 2006 | 02:40 PM
OBE1 95Z28's Avatar
There's also an electrical connector for the low coolant sensor that you'll need to unplug; it's located just below the radiator fill neck.
Photo from Shoebox's page: http://shbox.com/1/low_coolant.jpg
Old May 17, 2006 | 10:16 PM
sorry, just now getting back online, lost internet.. i got it done and it wasnt to hard just a pain. thanks for the input
DirtyDaveW
Dec 1, 2016 05:37 PM
captcorvette
Mar 7, 2015 12:37 PM
mark0006
Feb 3, 2015 05:12 PM
Jan 23, 2015 01:13 PM
