Easy way to R&R Radiator?
Re: Easy way to R&R Radiator?
You don't have to remove the condenser, just unhook it from the radiator. Below is from my cam removal guide.
- Remove all hoses to the radiator.
- Remove the radiator cover. (three 8mm bolts on top)
- Disconnect and remove fan assembly. The fan assembly is hooked to the radiator side tanks and can be lifted up to unhook it and then lowered out the bottom.
- Disconnect the transmission oil cooler lines from the radiator (if applicable). (1/2" fitting - flare nut wrench recommended) A small amount of transmission fluid will come out. I used a couple of plastic plugs I had to cork the transmission line fittings in the radiator, so that it would not drip as I removed the radiator.
- Unplug low coolant sensor connector.
- Release a/c condenser line from guide on bottom passenger side of radiator tank.
- Lift up on a/c condenser to unhook it from the radiator. Remove the radiator by pulling it up out of the lower saddles. Try not to damage the fins.
CJ Black LS1 Z28 M6
Oct 31, 2003 11:07 AM
