Dyno and Track Results 230/236
Old Mar 9, 2003 | 10:15 PM
  #31
Smokn '94 Z's Avatar
Thumbs up
Originally posted by blkn'silver94
Hey Ken..do think that the 3.42's were perfect for the hotcam?...i have your exact same set up(before the swap) however with a 2200 RPM stall and 3.73's...should it even out since you have a larger stall or are the 3.73's too much for the hot cam..any advice appreciated...thanks Tony
I am running 3.73's along with a 3200 stall & basically the same set up as you mention. I think with a bit of weight reduction & some slicks I would be running close to what Ken ran with his set up. I think 3.73's are good too.
Old Mar 10, 2003 | 01:25 AM
  #32
blkn'silver94's Avatar
thats my goal...to bad i cant get to the track for another 2 weeks..i cant wait Tony
Old Mar 10, 2003 | 02:45 AM
  #33
chesee48's Avatar
It was u who won the free cam?
Old Mar 10, 2003 | 08:12 AM
  #34
Ken95Z28's Avatar
chesee48 - Yup, I won the cam.
jmzlt1 - Still a 350 with 70k on it. Just freshend up the bearings on it.
MadMav - They seem to be doing the job.
Smokn'94 Z - Looks like I will go ahead and get some 3.73's and see if that does not help more. The other option is to go with the 4.10's with taller tires.
Old Mar 10, 2003 | 08:18 AM
  #35
CANTONRACER's Avatar
What does your car weigh in at race weight?
I am just curious because my car I figure to weigh with me around 3650 and I dynoed 359/450 and the car ran in the sig last year.
Old Mar 10, 2003 | 09:12 AM
  #36
Shon Herron's Avatar
Very Cool!! I would go with the 4.10s and pull the RPM at the top end!!!
The 3.23 vs 3.73s gave me 3 tenths with my set up with the A4...not sure about the Th350, still working the combo out.
Old Mar 10, 2003 | 09:23 AM
  #37
i gained about .05 from 3.23's to 3.73's....
Old Mar 10, 2003 | 10:03 AM
  #38
Gripenfelter's Avatar
I wonder how much horsepower you really have at the flywheel since the high stall swallows alot of it.
Old Mar 10, 2003 | 11:01 AM
  #39
Ken95Z28's Avatar
Car weight is 3500 lbs with me in it.
I currently have 3.42's in it. Just not sure I would see a big enough gain with the 3.73's. It would be cool if they made some 3.90's that would fit the 10 bolt that we have. I just think the 4.10's might be to much without a tire change on the back. I need to run it through a gear calculator and see the RPM.
Old Mar 10, 2003 | 11:11 AM
  #40
Camaro37's Avatar
Summit sells 3.90 gears for the 10 bolt.
Old Mar 10, 2003 | 11:13 AM
  #41
RealQuick's Avatar
Ken - If you dont mind, what were your flow numbers for the heads, or atleast what were the peak numbers?
Old Mar 10, 2003 | 11:34 AM
  #42
96z's Avatar
96z
Nice Ken.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Flint78
Jun 21, 2015 01:28 PM
Feffman
Events and Cruise Spots
Jun 4, 2015 05:44 AM
TitoPR221
May 26, 2015 12:20 AM
BLK1997Z28
May 7, 2015 03:01 PM
