Dyno results question?
Again, we don't know what he means by 10% lean. But variations from max power AF ratio work like this - as you lean it out from optimum there is power loss pretty much in proportion to how lean you make it. The EGT will also get hotter and eventually you can melt things. A little richer than the max power mixture results in less power loss than going to the lean side. That is one reason stock tunes are a bit rich.There is a safety factor built in so that if the air is very good, you get gas with a low specific gravity, etc. it will not be too lean and risk engine damage and there is very little power loss being a little rich anyway. One of the reason people who can run alcohol like it so much is that it is quite forgiving of a rich mixture. The tune is more forgiving than gas.
Regardless of the fuel, they all must be richer than stoichiometric for max power. NA cars on gas like low 13:1 AF ratios. Blower cars need richer mixtures.
Rich
Rich
IgorT.455/406
Mar 12, 2015 03:39 AM
