dyno results.. nitrous
Old Sep 18, 2006 | 10:30 AM
  #31
01Z's Avatar
01Z
Re: dyno results.. nitrous
255 Bridgestone Comp TAs. Not a sticky tire from my perspective. Too much relief between tread lines that is all linear. Sort of all weather I think.... I have my eye on some nitto 555s. I have to watch because when I changed my differential to the zexel the sides of the C clips were worn from the axle grooves which are also worn. Plus I was stupid when I bought the diff and got a 2 series which made me go with a spacer. On an automatic that's okay but add some sticky tires like you have and I might need to be trailered home.
I just got back from the store with supplies for the scanmaster install. I'm not going to make it for tomorrow. Dragway 42 here in W. Salem has T&T on fridays as well. More crowded but I might make it then. Keep posting your progress please.
Old Sep 18, 2006 | 10:37 AM
  #32
I'll change his pic to a link.... I wish people wouldn't post oversize photos and screw up reading the thread
Old Sep 18, 2006 | 10:41 AM
  #33
And just looking at the graph (guy who started the post), with all the backtracking and loops, you've got a problem with the ignition, or they didn't get a clean hookup on the timing signal on #1. The dyno computer is seeing the RPM drop and jump erratically, which causes the erratic graph. I'm surprised the shop even gave you a graph that looked that bad, at least without explaining to you why it happened.
Old Sep 18, 2006 | 12:51 PM
  #34
camzaro28's Avatar
he said i needed to get my iginition checked out.
the erratic jumping of rpms, i beleive that is the surging and popping that i have noticed lately.
car goes good, then stops pulling, then pulls again.
yesterday i installed all new plugs, but have yet to take the car out. i dont think they were the problem though. 2 of them had some buildup on them, if i had a good camera i would post pics.
wires are near new, msd coil is 1 1/2 years old, have never messed with the ICM or the opti.
Old Sep 18, 2006 | 12:59 PM
  #35
2000GTP's Avatar
Still very nice and modest gains despite the problems. Be sure to post the new results when everything is figured out and fixed.
Old Sep 18, 2006 | 02:04 PM
  #36
86 IROC's Avatar
Originally Posted by 01Z
I'm positive I won't be seeing 12s with my 125 zex shot. What I have seen is about .8 gains from other posts so I'm hoping to see low 13s.
I hope not, the kit on Brian's 97' is off of my LS1 car, I saw a .9 & 9 MPH improvement in the 100*+ weather with a 100 shot and barely 900psi of bottle pressure. That same 100 shot in the cold w/ 1000-1050 psi gave me 11 MPH. Lots of spin on that pass, so despite the 11 MPH of trap speed... I only picked up like .5 - .6 on that pass.
I wouldn't be afraid of the rear, I've seen violent launches on stock rears before. Hell, my stock 10 bolt has many launches on ET Streets and a 150 kit.
Old Sep 18, 2006 | 07:19 PM
  #37
indirocz28's Avatar
sorry, it wasnt meant to be that big. when i scanned it in it showed up as smaller. And when i posted it to imageshack it for some reason resized it.
Old Sep 18, 2006 | 07:22 PM
  #38
2000GTP's Avatar
So how much timing did you have pulled with the nitrous shot?
Old Sep 18, 2006 | 07:23 PM
  #39
indirocz28's Avatar
who are you refering to?
If your refering to me- none- i let the computer do it. not to mention - it only runs at like 27* anyway..
Old Sep 18, 2006 | 07:26 PM
  #40
2000GTP's Avatar
Sorry, I was referring to the original poster, I should have clarified.
Old Sep 18, 2006 | 11:50 PM
  #41
camzaro28's Avatar
i didnt have any pulled. on the street i did 6 and 15, and on both them runs that car ran like crap.
next time i go to the dyno, i will mess around with it. but SOTP and the way the car felt with timing pulled, the car was slow and didnt run right.
Quickss96
Jan 29, 2016 05:56 PM
fift5
11
Oct 1, 2015 10:31 AM
95blkss
Sep 22, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
