dyno results.. nitrous
Old Sep 16, 2006 | 05:27 PM
camzaro28's Avatar
went and got the car dynoed today and pulled some good numbers on the bottle.
from the look of the graphs, i think i need some ignition upgrads or new opti, which is most likely the case.
anyway 150 jets in the car
[IMG][/IMG]
[IMG][/IMG]
273/284
426/427
what u guys think? i went in there hoping for 380, so i am ecstatic with the results.
Old Sep 16, 2006 | 11:00 PM
LT1 POWR's Avatar
Re: dyno results.. nitrous
A4 or M6. Your NA torque seems low either way. Need a full list of mods. Also are these SAE corrected.
Old Sep 16, 2006 | 11:34 PM
01Z's Avatar
01Z
I think you have some great numbers and I can see why you're ecstatic. You've managed to add 40 hp or so to the bone stock numbers and it looks like the 150 hp shot is giving you everything it advertises. Congratulations!
Old Sep 17, 2006 | 08:46 AM
camzaro28's Avatar
i got it dynoed around 2 years ago. 267/304, only difference since then is EWP and diff plugs. i THINK the TQ is lower due to my opti going out.
dyno numbers all around are lower due to the converter ( its an auto by the way ).
yes the numbers are corrected.
Old Sep 17, 2006 | 08:53 AM
Honda Hunter's Avatar
How do you know when youre blowing through the converter?
Old Sep 17, 2006 | 09:10 AM
86 IROC's Avatar
SAE corrected, 1.02 correction factor, it was over 100* ambient air temp in the bay where the dyno was. #'s are with an unlocked converter, would be a little higher locked obviously.
Mods: Let me see if I remember this right... Fuddle 3200 2.0 STR, Pacesetter LT's & ORY, bullet muffler after the Y, K&N CAI, EWP, BBK crank pulley, TR6's @ .035" gap, Taylor wires w/ OVC looms, mail order tune, 255lph walbro pump. Car has over 80K miles, stock opti-crap, 3.23's, no dyno tricks...
NX jetting calls for 62N/35F, that's what is in the nozzle.
camzaro28's Avatar
i have no idea. just heard that the bigger converters eat up some HP.
Old Sep 17, 2006 | 09:22 AM
'94 Bad A Z28's Avatar
The TQ seems way low.... my car did more than that on a 100 kit, 2 years ago or so before I did a lot to the car.
Old Sep 17, 2006 | 09:24 AM
My car also went 12.119 @ 115.45 @ OSW on the same kit/same pressure so there is deffinately something up with your car or your kit.
Old Sep 17, 2006 | 09:34 AM
86 IROC's Avatar
Eddie, the #'s in his sig are w/ a bad fuel pump and the car leaning out bad. Haven't run the car since the dyno yesterday... I'm willing to be it will trap better than 109-110.
Old Sep 17, 2006 | 09:36 AM
camzaro28's Avatar
yeah we are thinking its my opti. going to order today or tomorrow.
it pops alot on the bottle with a lil surging. on motor it pulls fine with a lil surging also.
Old Sep 17, 2006 | 09:50 AM
mthegodfather's Avatar
Hopefully the Opti will cure it.
Old Sep 17, 2006 | 09:58 AM
Yeah, I'd hope so, lol... thatmakes more sence then.
What have you been up to, haven't seen you in forever.
Old Sep 17, 2006 | 10:03 AM
86 IROC's Avatar
Eh... broken car woes. Death & illnesses in the family, layed off last month. Kinda been laying low, when the weather cools off and things go back to normal - you can expect to see me & the car more often.
Old Sep 17, 2006 | 03:12 PM
Do you have clearer/larger photos of the dyno sheet? Looks like its jagged on the initial hit and then does a few spirals on the back end???????
