Dyno Results
Old Aug 13, 2008 | 08:57 PM
slomarao's Avatar
Dyno Results
Well went to Speed inc today. Came back pretty happy.
95 z28 bolts ons, very light headwork- 323 rwhp 338rwtq.
Dont have the graph yet, still need to get it emailed to me from Larry.
HP mods to the car:
Mac shorties
Crane gold 1.6rr
Hooker catback
Mac crank pulley
Ls1 DS
52mm tb
1le elbow
PCM4LESS tune
airfoil
e cutout
no cat
lightly worked heads and intake, mainly gasket matching. My buddy did the headwork.
Conditions- 86.6 F, 33% humidity, reved the car to 6200rpms. No air fuel ratio. Its a flat 45 degree slant up. I will try to get it up tomorrow.
http://i2.photobucket.com/albums/y28.../Misc/dyno.jpg----Heres the graph.
Whats hurting me is an exhaust leak near the y pipe and where the catback mates up. Also the headers need to be tightened again. And the 3.73 gear ive got in the good old ten bolt.So i think theres another 5 hp there.
I pretty much have every bolt on except a ewp and LT's. I still have a mallory ign, wet kit and a LS1 lid to throw on the car. So i think when everythings said and done it may do 340rwhp with the items ive listed and once my leak is fixed.
Overall I am i couldnt be happier. I am probably going to need injectors once everything is done but that would be a good thing. I had to do headgaskets recently because of a waterpump failure so thats why i have work done to the heads and intake.
I would of done a cam too but ive got 119k on the shortblock and dd the car. I think i should be happy with what ive got and the spray. But if i cant run 12's with it I am going to jump off a bridge.:
Old Aug 13, 2008 | 09:00 PM
mad95z's Avatar
Nice results for what you have done to your car.
Old Aug 13, 2008 | 09:18 PM
slomarao's Avatar
The first pass i made was 320/335 rw. The 2nd is the numbers above.
The list of mods is right there. I didnt list things that dont contribute to the hp. I have koni 4/4's and a bmr sus.,18inch zo6 rims. but that doesnt have anything to do with the dyno numbers.
Old Aug 13, 2008 | 09:20 PM
SnakeOiler's Avatar
stock camshaft??
Old Aug 13, 2008 | 09:22 PM
slomarao's Avatar
ya, im a puss. Cant risk it, its my dd.
Old Aug 13, 2008 | 09:50 PM
LSWHO's Avatar
That's awesome! 503 cammed cars put out barely more power!
Old Aug 14, 2008 | 06:56 AM
SnakeOiler's Avatar
no kidding - I'm obviously missing a lot of power somewhere.
Old Aug 14, 2008 | 08:01 AM
jsetzer's Avatar
Nice job, my 306 cam barely made those numbers.
Old Aug 14, 2008 | 08:35 AM
slomarao's Avatar
Thanks guys, I have poured more money into this car than i can count so im glad it put down the numbers it did. Gives me some relief.
Old Aug 14, 2008 | 09:09 AM
CANTONRACER's Avatar
Why do you need injectors?
Dyno numbers are not the end of of performance...see how it runs.
Old Aug 14, 2008 | 09:41 AM
slomarao's Avatar
I dont, I hope to need them when i try and crack 340rwhp.
Old Aug 14, 2008 | 10:36 AM
97SS0594's Avatar
what was your injector duty cycle? if your under 80% your good to go, even the low 80's are acceptible.
Old Aug 14, 2008 | 11:36 AM
slomarao's Avatar
I dont know? They done tune obd1 cars so i dont know my a/f ratio either. I have a wet kit thats going on, it may end up as a dry kit so im going to need more injectors anyways. I understand DC and how it works, i wouldnt go past 80%.
Old Aug 14, 2008 | 11:04 PM
JakeRobb's Avatar
Super Moderator
Nice. Pretty similar to my numbers (325/343). Say hello to 108-109mph traps, and ETs in the high 12's if you're willing to put a decent tire on it.
What clutch are you running?
Old Aug 15, 2008 | 08:42 AM
slomarao's Avatar
stock clutch. Its got 60k on it too. But theres still lots of life in it. I can drop it into 2nd or 3rd at 60-80mph and it grabs very well, doesnt slip at all.
I have some bfg dr's on stock 16's. I think i can run 12.80's @ 108ish.
I have the graph but cant figure out how to post it. I can email it to someone if you guys want to see it.
