Dyno numbers in! w/355 heads and cam
Old Mar 28, 2003 | 09:35 PM
  #46
Ai's Avatar
Ai
Brain,
He's running stock stuff. This isnt a big *** cam.. it's got less overlap than a cc306, which is an easy daily driver with tuning. There's 6 or 7 guys running the same topend/cam with stock gears in their daily drivers. It isnt bad at all, but I'd always suggest a little shorter gear.. hell you've got a .5 OD with a 6speed, there's no reason not too .
1fasasz, we usually try to keep it under 11.33:1 since there isnt enough power going over 11:1 to matter. Hopefully he can dyno again now that some fuel system stuff has been fixed
Old Mar 29, 2003 | 10:09 AM
  #47
NightTrain66's Avatar
Steve, I am glad that the #'s are coming around for ya.
What did you do to fix the KR?
LT4 KM?
Disable it?
colder plugs?
Any idea what the A/F is?
Any more trix up your sleeve?
NightTrain66
Old Mar 29, 2003 | 04:09 PM
  #48
SABLT194's Avatar
Lloyd,
Sunoco GT 100 took care of the knock problem on the dyno. I still get a blip of knock counts every time I shift on the street. I'm pretty well convinced it's garbage noise so I'll set my KR to zero at the track. I tuned AFR to 13.0 to 13.2 across the RPM range. I had AFR dialed in on the second pull. I was rushed for time so I didn't fool with timing. I was seeing about 32 deg at 2600 and it ramped up to 39 deg at 6400
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
