dyno numbers for stock 93 M6
Old Apr 6, 2008 | 09:25 PM
key3's Avatar
Hi, I came across a 93 Z28 M6 pretty cheap about a month ago and a new dyno shop opened and where running a special 3 pulls for 50 dollars. This is only the second time I have been around a dyno and all I know is its a dynojet and some reason they had to weld an O2 bung on it. Anyhow the car has 160K on it someone put a single inlet and single outlet flowmaster and I just put a 160 stat other than that its stock. It put out 255.86 HP and 294.27 TQ. I know this is pretty normal for a stock M6 LT1 but with a 160K on it I thought it was pretty good. Also what is the air/fuel ratio supposed to be at it never got above around 12.5?
Josh
Old Apr 6, 2008 | 09:46 PM
Probably want the A/F ratio closer to 12.8-13.0:1. But stock programming is very rich in PE mode (WOT).... usually targetting ~11.7:1. Leaning out the stock tune will usually net you 10-15HP.
Old Apr 6, 2008 | 09:56 PM
key3's Avatar
How do I get it leaner closer to the 12.8 to 13.0:1?
Old Apr 6, 2008 | 10:01 PM
You have to have a new chip burned, leaning it out using the PE tables. You can get mail-order custom chips.... one example is pcmforless.com
Old Apr 6, 2008 | 10:07 PM
LSWHO's Avatar
Tune would work. When I was stock my car was INCREDIBLY lean. I can't believe I didn't blow the motor. Probably why the previous motor was blown though...
Old Apr 6, 2008 | 11:33 PM
stereomandan's Avatar
Numbers are right on for a well maintained LT1. Must be running well. Congrats
Dan
Old Apr 7, 2008 | 06:18 AM
key3's Avatar
Thanks guys, I am going to check into getting a chip burned. Yea car runs great, all I have been around is automatic LT1's and this one is by far the fastest.
Josh
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
canbaufo
May 25, 2015 12:01 PM
Roadie
Feb 16, 2015 10:34 AM
Jlo
Feb 3, 2015 09:41 PM
