dyno numbers for stock 93 M6
Hi, I came across a 93 Z28 M6 pretty cheap about a month ago and a new dyno shop opened and where running a special 3 pulls for 50 dollars. This is only the second time I have been around a dyno and all I know is its a dynojet and some reason they had to weld an O2 bung on it. Anyhow the car has 160K on it someone put a single inlet and single outlet flowmaster and I just put a 160 stat other than that its stock. It put out 255.86 HP and 294.27 TQ. I know this is pretty normal for a stock M6 LT1 but with a 160K on it I thought it was pretty good. Also what is the air/fuel ratio supposed to be at it never got above around 12.5?
Josh
Josh
Probably want the A/F ratio closer to 12.8-13.0:1. But stock programming is very rich in PE mode (WOT).... usually targetting ~11.7:1. Leaning out the stock tune will usually net you 10-15HP.
