drive shaft vibration
Old Oct 13, 2003 | 10:03 PM
apick42's Avatar
ok i needs some help on this one. after my stock trans mount
broke i replaced it with a poly mount. i have had a drive line vibration ever since. the mount came with a pre load spacer and i removed it and that made a differance in the amount of vibration but it did not take it all away you will start to feel it around 65 -70. i know that f bodys had a problem with unblanced shats so i bought another one and had it balanced and new u joints put installed it was worse than the old drive shaft. ok here is the question after searching on line about this problem i ran across a messages board that stated that on 93-97's a poly mount can not be used because it puts the trany at the wrong angle. is this true have i wasted money for nothing?
93 t/a 700r4 3.23 rear end cold air / air foil
flow master muffler.
Old Oct 13, 2003 | 11:03 PM
Zpower's Avatar
all i know is that after i installed my prothane trany mount, my car got a nasty vibration at speeds over 70mph. at 110 it feels like somethign is about to fly out. scary. but my stock tranny mounts dont last at all.
Old Oct 14, 2003 | 02:38 AM
Zepp's Avatar
Get an aluminum driveshaft.
Old Oct 14, 2003 | 09:33 AM
Chris 94Z A4's Avatar
Post
Get the 1LE trans mount bushing and 1LE driveshaft.
Old Oct 14, 2003 | 09:38 AM
Brundle's Avatar
i bought an energy suspension poly trans mount and it was garbage. created vibrations all the time. i took the poly one back and put a new stock one on instead and no vibrations what so ever.
when the car was idling, the shifter was getting a lot of vibrations b4 any tampering, but with the new OEM one, it barely moves now. i would just go back to a new stock one if i were you
Old Oct 14, 2003 | 12:00 PM
95 WHITE TRANS's Avatar
Get the aluminum driveshaft from GM day and night diffrence from the stock one.
NICK
Old Oct 14, 2003 | 12:32 PM
buelldevil's Avatar
I have the same thing on mine. I have seen a post about the drive shaft being turned out 180deg. I have not tryed it yet myself. Do a search on here for the post.
Old Oct 14, 2003 | 11:43 PM
Zpower's Avatar
i guess im going to have to go back to a stock one. but dam, they dont last long before they break.
Old Oct 15, 2003 | 03:48 AM
jkipp84's Avatar
I'd stick with the steel over weak aluminum. SLP has an HD steel one for $199. Looks like a pretty good.
Old Oct 15, 2003 | 08:55 AM
BlownF1's Avatar
Yup, it's very common for A4 owners to complain of vibration when going to a poly mount. Had mine for 2 days before I yanked it back out! Get the 1LE rubber one and it'll last longer than the stock one and transmit far less vibration. I've got an aluminum driveshaft, and that by itself will not solve the problem.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
