draglites...what size?
Old Jan 23, 2004 | 09:01 AM
TUFF LT1's Avatar
I'm looking at getting a set of draglites but wanted to get some knowlege about them first. I see lots of people are running 15 X 10's, but what about the back spacing do I need to know? If I buy wheels now that will fit my stock 10 bolt will they fit a different rear if I blow my stocker ? Any info will help Thanks
Old Jan 23, 2004 | 09:21 AM
TRIPLE G's Avatar
You will have to grind the calipers down with 15in welds.
Old Jan 23, 2004 | 09:23 AM
TUFF LT1's Avatar
How much grinding will I have to do?
Old Jan 23, 2004 | 10:24 AM
steve10's Avatar
Check out Bogart rims www.sjmmanufacturing.homestead.com , they are lighter, designed to be a direct fit, not to mention more choices in styles. Much higher quality then a prostar or draglite rim.
Steve
Old Jan 23, 2004 | 10:52 AM
TUFF LT1's Avatar
Hey, thanks Steve! Awesome link!
Old Jan 23, 2004 | 11:02 AM
mongse_1's Avatar
Normal backspacing is:
15x10: 7.5"
15x8: 5.5"
As long as you've got about 2-2.5" of spacing, you're fine. My old Centerlines were x 15x7.5" or so w/ a 5" backspacing. Looked perfect.
Also invest in a good die grinder and a LOT of bits. You'll need them to take down the calipers. At least you've got an LT1. LS1s are even worse.
Old Jan 23, 2004 | 11:37 AM
TUFF LT1's Avatar
That really cleared things up! Those were the numbers that I was looking for. Thanks for the reply mongse_1!
Old Jan 23, 2004 | 03:57 PM
Here is a picture of a ground caliper.
If it fits on a 10-bolt, it will fit on a 12-bolt or a 9-inch, as long as you are using the same calipers. Note Strange axles in picture.
Old Jan 23, 2004 | 05:12 PM
TUFF LT1's Avatar
That's good to know about fitting the different rear ends because I think there is a good chance that my stocker won't hold up too long after my heads and cam swap is finished! Thanks for the info.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
