dose a 93 lt1 have a mass air flow sensor???
Old Aug 5, 2010 | 07:11 PM
camaro9778789's Avatar
my 93 camaro dosent seem to have a maf i didnt know if this was normal or not??? i seen a 95 camaro and noticed they had a maf
Old Aug 5, 2010 | 07:15 PM
dangalla's Avatar
no it doesn't, the 93, and only the 93, used a speed density system
a search should yield alot of information on exactly what this is and how it works
Old Aug 5, 2010 | 07:31 PM
ok thanks another question for ya do u know of anyone who has one of these or f they even work??
http://www.summitracing.com/parts/JET-19314S/?rtype=10
Old Aug 5, 2010 | 08:15 PM
n2ceptor's Avatar
I used Hypertech Thermomaster w/ 160 thermostat on my 93Z for 4 years on my stock motor before rebuild..... Jet, not that good....
Old Aug 5, 2010 | 08:29 PM
ok thanks alot im gunna get this one...
http://www.summitracing.com/parts/HYP-123322/
Old Aug 5, 2010 | 08:41 PM
lt1-xjs's Avatar
Your money would be better spent ordering a bolt-on tune from a tuner. I use pcmforless myself and most require the 160* thermostat.
Old Aug 5, 2010 | 08:53 PM
Even if you car is lightly modded, a custom tune (in your case, a chip) would be better than a "tune-in-a-can".
Old Aug 5, 2010 | 08:58 PM
i went to that pcm for less and the beginning year for the pcm is a 1996 so mine wouldnt work being a 93. you guys think that hypertech chip from summit is a no go for the money?
Old Aug 5, 2010 | 10:27 PM
RamAir95TA's Avatar
OBDII started in 96. PCMs began in 94 (OBDI). 93s had ECMs.
Old Aug 5, 2010 | 10:52 PM
pcmforless can burn a chip for your 93. Alvin burns the chips:
http://www.pcmforless.com/index.php?...d=20&Itemid=78
Old Aug 6, 2010 | 01:28 PM
faded93bird's Avatar
Also check out www.speeddensity.org
Lost of 93 info there too.
Faded
Old Aug 7, 2010 | 07:18 AM
M93Z's Avatar
Sent PM.
Old Aug 8, 2010 | 08:03 AM
allright great thanks alot guys!
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
