Does synthetic oil cause lower oil pressure?
Old Apr 2, 2010 | 03:42 PM
wrd1972's Avatar
I recently switched from Penzoil dino 5w30 to Mobil1 synthetic 5w30 and I have clearly less oil pressure now. I would speculate maybe 5# less at idle and 10# everywhere else. Is this normal?
Old Apr 2, 2010 | 04:09 PM
Paul94Z28's Avatar
Interested
I can't add anything here to help, but I am experiencing something like this on another car I have. Would like to hear opinions...
Old Apr 2, 2010 | 08:27 PM
94Z28LS1toLT1's Avatar
Red face oil ?
so u fellas are talking about oil i have a ? im using mobile 1 10W30, i live in las vegas last year i had experieced oil pressure problems my gauge droped to 0 and wrecked my engine.
but that was due to the oil drive gear stripping!!
anyways wat kind of oil should i use during the summer it gets to 115 to 120 here in las vegas.thank u
Old Apr 2, 2010 | 10:54 PM
Max Lewis's Avatar
I noticed lower oil pressure when I used Mobile One and I was using 15w-50. I switched to Castrol synthetic and noticed the pressures went back up.
Old Apr 2, 2010 | 11:11 PM
6SpdLT1Z's Avatar
Synthetic is thinner. Basic chemistry... thinner viscosity, lower pressure
Old Apr 3, 2010 | 06:40 AM
Ummmmm..... viscosity is viscosity. A "30" weight (looking only at the high temperature portion of the diesignation) oil must have a viscosity that falls into the range specified by SAE. Because is it a range, some "30" weight oils can be slightly thicker (more viscous) or thinner (less viscous) that another "30" weight oil. Checking the manufacturers tech data sheets for the Pennzoil conventional and the Mobil 1 synthetic, the Mobil 1 has a lightly higher viscosity than the Pennzoil, so that theory goes out the window.
Old Apr 3, 2010 | 03:51 PM
wrd1972's Avatar
Yeah I saw that too. Somehow the M1 has reduced my pressure. I am going to put some Penzoil conventional back in to recheck. Its not dangerously low, I just dont like the reduced pressure.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 31, 2015 07:29 PM
jp2002ls1
Aug 30, 2002 08:18 PM
redz_02
Jul 24, 2002 09:42 AM
