Does this mean my fuel pump is bad?
Old Jul 30, 2007 | 09:41 PM
Built LT1's Avatar
My car is cutting out at part throttle, or as soon I give it any moderate acceleration.
If the pressure is dropping, is it most likely the fuel pump going out, or a loose wire/crimped fuel line?
Old Jul 31, 2007 | 10:00 AM
WhyHelloOfficer's Avatar
Get a fuel pressure gauge on there to check.
When you say cutting out, do you mean like a hesitation or backfire? Does it only occur when the car is driving (under load)? Does it happen when the car is cold?
Old Jul 31, 2007 | 10:33 AM
Built LT1's Avatar
I'm going to get a guage on it soon here. The instant it goes under any load, it simply cuts out completely, no backfire. After about one second, it drives like normal.
Old Jul 31, 2007 | 10:50 AM
2000GTP's Avatar
Put the gauge on it, if you see the fuel pressure dip under WOT, then you know you have a fuel related issue.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
