Do Not Remove Your Maf Screen!
Old Feb 27, 2003 | 03:38 PM
  #46
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i honestly dont think the MAF is providing enough restriction to matter on a stock car.
sorry, JMO.
until someone has dyno results (after it has be recalibrated for no screen, it will just run a bit leaner without tuning), i say its not even worth the effort.
why is it there? GM bored?
Old Feb 27, 2003 | 03:43 PM
  #47
RedWolf's Avatar
Originally posted by RedWolf
T.P.I.S.(www.tpis.com), did a write up in thier LT-1 Hint book which says:
Flow restriction for the 1994 Camaro with LT-1.
CFM
test 1 all stock.......................409
test 2 TPIS air filter................428
test 3 remove first air entry
(that little vent behind the
dr head light)..........................447
test 4 drill 7 holes
in the filter cover......................475
test 5 hi flow elbow between
MAF and filter assembly............535
test 6 remove MAF screen........559
test 7 52mm with air foil...........605
test 8 remove air filter lid..........618
test 9 remove air filer base.......726
so as you can see.. removing the screen DOES increase your air flow, according to them.
just thought id share with you all.
here ya go
Old Feb 27, 2003 | 03:47 PM
  #48
treyZ28's Avatar
here ya go
because that looks alot like a dyno to me! especially one of a car thats been tuned.
mike you amaze me
you bash me all the time
you bash PROFESSIONAL engine builders opinions
you bash their dyno results
you bash my opinons
you bash my track results
but yet- all you have is your opinion and a thoery to EVER back yourself up . your opinion, thoery and 4 quarters will get you a dollar ANYWHERE you go mike
Old Feb 27, 2003 | 04:07 PM
  #49
Brent94Z's Avatar
Super Moderator
Here are the numbers I said I would post earlier...
Flowbench measurements on the MAF (Superflow 300).
Measurements were made at 3" and converted to 28" (water).
(B-body) 3" MAF w/ screen = 670 cfm
(B-body) 3" MAF w/o screen = 808 cfm
(F-body) 3.5" MAF w/ screen = 759 cfm
(F-body) 3.5" MAF w/o screen = 979 cfm
Oh, and GREGG 97Z, I don't currently have the Trans Am anymore Me and a buddy traded vehicles. I got me a red neck 4x4 chevy truck and he got my Trans Am. However, I did end up with another 96SS but I don't have the engine in it right now so it is kinda like only 1/2 a car I guess. LOL!
Old Feb 27, 2003 | 04:27 PM
  #50
Josh-'04 GTO's Avatar
First, I'll take 200+ CFM of intake flow anyday I can.
Second, GM puts lots of parts on our car that are not always in the best interest of power....example stock cam, muffler, etc. I think the more important question is why does the '02 ZO6 NOT have the screen?
Old Feb 27, 2003 | 04:28 PM
  #51
GREGG 97Z's Avatar
Brent, That's a nice looking truck! I didn't see a shotgun rack in the back window so I wouldn't call it redneck.
So 2 1/2 F-bodies and a pickup now, not bad!
Old Feb 27, 2003 | 04:53 PM
  #52
Mizz96Z28's Avatar
I ported and polished my MAF and I get rough idleing but thats it. I notice more throttle response and actually get better gas mileage then with a regular stock MAF ( I have an untouched MAF that I used to compare). Something else is most likely up with your car. How old is the air filter and what kind is it?
Old Feb 27, 2003 | 05:30 PM
  #53
AlexBarabas's Avatar
Might this have anything to do w/ the OBDI/OBDII crap? I heard my friend babble something about that and how some people need to reprogram the ECU to run w/o screens.
Old Feb 27, 2003 | 09:52 PM
  #54
Compstall's Avatar
Originally posted by LT1InternetGuru
why would you do it to begin with
i'm sure that screne is a HUGE restriction
uh, yeah, just like "unshaved" spark plugs...
Old Feb 28, 2003 | 12:40 PM
  #55
Joe Brodman's Avatar
GP Moderator
Read 5 posts up, then say you are sorry.
Old Feb 28, 2003 | 12:45 PM
  #56
JeffK95Z's Avatar
I've had the the screen out of my MAF for the past 5-6 years as well, and while I don't have any major issues with it, I do have some hidden? ones that I am some what convinced are due to the lack of a screen.
BLM's... Long term fuel corrections...
Sideways, thats a great test you did, but did you notice if your BLM's changed from the MAF switching?
I also wanna do a test like this, as my car runs rather rich... And while there might be other reasons for this (leaking injectors, etc...) I don't feel that there is ANY need to remove the screen and wish I didn't all those years ago...
I also think that the people talking about the Z06's and its lack of screen (I think anyways!!) have to think about how the air duct from the Z06 is... Its straight isn't it?? So it doesn't need a screen to even out the flow... As our ducting goes arounds bends and such, we need something to even out the rough airflow...
I look forward to some testing with a perfectly working stock MAF
Jeff
Old Feb 28, 2003 | 12:53 PM
  #57
BAD 97 WS-6's Avatar
Brent always comes thru when needed.
I have had my MAF screen out since 99 with NO PROBLEMS.
Dude, you have a bad MAF.
Old Feb 28, 2003 | 12:57 PM
  #58
RedRyder518's Avatar
Originally posted by neil350
M A F, Mahhhhhhhffffff, sounds funny to us 93 owners.
LMFAO I dont know why, but that was funny as ****.....
Old Feb 28, 2003 | 01:07 PM
  #59
97FormulaWS-6's Avatar
Jeff
I went into this a while ago.... No one wanted to listen to my logic.... Even though I'm a senior ME student who's fairly well versed in Fluid Dynamics.....
But you did stumble upon a HUGE thing... The screen makes a uniform flow across the meter and compensates for all the bends in the tubing... Without the screen you have un-balanced flow across the meter... Atleast in a "typical" setup. A LS1 or WS6 setup is the exception....
Old Feb 28, 2003 | 01:09 PM
  #60
scoobie30th's Avatar
Ill trade someone my totally stock MAF with screen still installed for a Granatelli !
