Do Not Remove Your Maf Screen!
Old Feb 26, 2003 | 06:11 PM
BackInBlackZ28's Avatar
Exclamation Do Not Remove Your Maf Screen!
I know this has been debated back and forth, and i went the wrong way. i got my camaro about 8 months ago, and did all the free mods, one of them being descreening my MAF. I didnt really know abnout this board at the time, it ewas just somehting i had heard to do. AFter doing it, i thought i could feel a little difference, but did not feel any driveability changes. The car still ran smooth, and everything seemed good. i noticed about 3 months later that my car was starting to develop a rough idle and my gass millage started to drop. Now 5 months after the descreeening, my car shakes like crazy at a stoplight, and i am getting about 8MPG! After reading som threads a few months ago, i found that the MAF could be the problem. I swapped it 2 weeks ago with my buddies 96 Z and OMG the differnce was amaizing. Back up to 15-18 MPG, and the smoothes idle ever. So this is for everyone who thinks descreening their maf is a good idea: IT IS NOT! DO NOT DO THIS!!! Even if your car runs fine just after doing it, wait...you'll see. I just hope you others cxan learn from my misfortune . and, if you would like a ported MAF, i will trade someone for a perfect one!) haha
Old Feb 26, 2003 | 06:22 PM
DOOM Master's Avatar
I'm still going to say what I say every time this comes up, you HAD to have damaged the sensor or had the sensor fail for what you describe. I've had my MAF descreened and self-ported for over 2 years, never had any problem. Know other guys with the same, no problems for even longer than me. If all you did was descreen, your MAF must have went bad. The way to check is if you put your screen back in and it does the same thing as your buddy's MAF. But it's not going to do that, because the descreening was not the problem.
Old Feb 26, 2003 | 06:25 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
why would you do it to begin with
i'm sure that screne is a HUGE restriction
Old Feb 26, 2003 | 06:27 PM
GigaMp3z's Avatar
I descreened mine..after about a 1-2 weeks my gas mileage went to crap. My sensor looks like crap too. I guess My SES light came on after taking the screen out, and for some reason I can't scan for it to no the problem? I am getting 10mpg. Maybe this is my problem?
-Corey
Old Feb 26, 2003 | 06:31 PM
I dont know it has never thrown a code and i descreened poted and polished. I was VERY careful, and everyting still looks to be in tip top shape. I found a guy who wants to trade cause he thinks thi is better o well see what happens. Maybe it has somehting to do with the rest of the mods done to the car as well?
Old Feb 26, 2003 | 06:35 PM
neil350's Avatar
M A F, Mahhhhhhhffffff, sounds funny to us 93 owners.
As far taking the screen out, from what I know, it wont cause any harm. People have been doing since 1985, with no ill effects.
Old Feb 26, 2003 | 06:42 PM
Grease's Avatar
Descreening your MAF won't make your car run like crap. What happened is you must have damaged or or more of the diodes and it went out of calibration. I've replaced hundreds of MAF sensors and one thing they all had in common is they still had thier screens in. I've also seen cars in the shop with their MAF screens removed but so far I haven't had to replace one of those. The main cause of MAF sensors going bad is dirt hitting the diodes and ruining them, usually from a dirty air filter or an air leak between the MAF and air filter. The screen won't stop small dirt, its there to straighten the airflow so it gets a more accurate reading of the airflow.
Old Feb 26, 2003 | 07:00 PM
my94blackz's Avatar
ok one quick ? for ya, how is the descreening gonna do that when the granitelli (spelling) comes w/o one???
Old Feb 26, 2003 | 07:03 PM
redlt1z28's Avatar
I wonder if this is why my gas mileage went down?
I descreened mine awhile back too but i am not sure if my gas mileage went down becasue of that or because i got rid of my cats? My idle is really rough too but i really dont think it has to do with the screen but i guess i could be wrong. What do ya'll think? I get about 13 mpg.
Old Feb 26, 2003 | 07:06 PM
Nuke's Avatar
I've had mine de-screened (initially by removing the screen and later by using using the Whisper MAF ends) since 1997 with no ill effects that I'm aware of.
Old Feb 26, 2003 | 07:13 PM
blownbird01's Avatar
I think that anyone that is only getting 10-15 mpg with just bolt ons, has something wrong. I was running 4.10 in a a4 with a supercharger and all the bolt ons, and still saw 17-21 mpg. As long as I was'nt full throttle everywhere. Like others have said, pulling the screen won't hurt the maf. It probably has some sort of damage from dirt or debris. I along with many people have done this mod and have had no problems.
Old Feb 26, 2003 | 07:39 PM
acayson's Avatar
Thumbs up
Hand ported my own and descreened it almost 2 years ago, was very carefull and have had zero problems. I did develope a rough idle after a while but that turned out to be a cracked plug. Runs like a champ. I was very carefull with my sensor and regularly check my air filter and and clean the sensors in the MAF with carb cleaner. Just a few squirts and they shine without touching them at all. Just wanted to share my positive experience with a ported and descreened MAF. IMHO I believe you damaged the sensors or your problem is beign caused by something else as stated above. Goodluck.
*Edit* I get 15-16mpg in the city and 27mpg on the highway.
Old Feb 26, 2003 | 07:42 PM
CODY BEHNKE's Avatar
I de-screened mine and still get 27mpg
Old Feb 26, 2003 | 07:47 PM
AHARTZ28's Avatar
i would try cleaning the MAF with brake parts cleaner then try it if its the same then the sensor prolly got messed up
Old Feb 26, 2003 | 07:55 PM
Greasepunk's Avatar
carb cleaner won't hurt the electodes in the maf? I've been wanting to clean mine, but I'm afraid that would hurt it. How many of you clean yours and with what products?? thanx
