Do I need an aftermarket fuel pump?
Old Dec 8, 2004 | 08:29 PM
JONEZ_Z's Avatar
With the engine in my sig, and a 150 shot, will I need to upgrade my fuel pump? I really dont have the money for it but I dont want to ruin my engine by leaning it out or something. Im supposed to have around 400-420 RWHP N/A. Thanks
Old Dec 9, 2004 | 06:39 AM
JONEZ_Z's Avatar
Re: Do I need an aftermarket fuel pump?
Ttt
Old Dec 9, 2004 | 09:55 AM
OBE1 95Z28's Avatar
Running out of fuel will definitely kill your engine! The only way to know for sure is to check it on the dyno with a wide band O2 sensor. This will also help you determine if your combo has been tuned properly. Proper tuning will give you safe power. I think with the 150 shot of nitrous you will be marginal with the stock fuel system. You could probably beef it up with an in-line pump to supplement your in-tank pump. The Racetronix in-tank pump is the better way to go; just a lot more work to replace the pump.
Old Dec 9, 2004 | 10:11 AM
SnakeSkinner28's Avatar
Very marginal at best with the stock system, especially with a 150 shot. You will need to get a 255lph pump, or at least a 190, but the differance in price is negigable. Check out the Walbro pump, its only about $150. But i would not use the stock pump with your setup.
Old Dec 9, 2004 | 05:53 PM
Racetronix's Avatar
Please read our ad to understand the factory FLT1 fuel system and what the Racetronix product has to offer over a generic off the shelf pump.
http://www.racetronix.com/Racetronix..._Pump_Kit.html
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
