distributor wire
Old Sep 28, 2009 | 07:52 PM
94Z28LS1toLT1's Avatar
distributor wire
i need help and i need sum1 to answer me ASAP please i have an 94 LT1 engine i got a distributor from a 94 caprice with an LT1 motor when i put the water pump on with all the bolts screwed in, i can't put/fit the distributor spark plug wire in. the plug for the distributor is close to the water pump,it doesnt let me put the spark plug wire in.and i would like to kno y i cant get the wire in.or why doesnt it fit in.please anyone out there
Old Sep 28, 2009 | 09:27 PM
I see one potential problem...a stock 94 Z has a non-vented opti. A stock 94 Caprice has a vented opti. How did you get the opti on there? The drives are totally different.
Old Sep 29, 2009 | 08:34 PM
the distributor went on there perfect i didnt have a problem getting it on.
Old Sep 29, 2009 | 09:37 PM
my mistake i have a 96 camaro LT1 motor i got the distributor from a caprice it was either a 95 or 96 cuz the part that inserts into the motor looks like a flower. but am i gonna have a problem with the wire touching the water pump, or will the wire get messed up from the pump getting hot cuz its close.or will the car start cuz i havent started up the motor yet i have a few more things to put on.
Old Sep 29, 2009 | 10:08 PM
I see. You neglected to provide all the needed info.
I don't know why you would be having a clearance problem. I've never heard of such a thing. Maybe some pics would help in understanding.
Old Sep 29, 2009 | 10:21 PM
would the wire be affected by the water pump if it gets hot man
Old Sep 29, 2009 | 11:07 PM
I don't think it could get hot enough to bother it. All the wires are in a pretty hot place.
Old Sep 30, 2009 | 06:45 PM
for sure man thank u
greenzee28
Mar 26, 2015 09:13 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
brentbrowning01
Dec 3, 2014 10:36 PM
