Distributor problems
Old Sep 15, 2006 | 03:49 PM
  #16
Re: Distributor problems
Originally Posted by bow94z
So the the Low Res DTC 16 is opti harness problem?
Depends.... a low res pulse pattern needs to reach the PCM. If the optical sensor is faulty, it can't send the signal. If the harness connector is corroded or the pins are bent, the signal can't get to the PCM.
Old Sep 15, 2006 | 05:06 PM
  #17
Bow94z's Avatar
is this something to worry about?? Stalled out 5 times within 15min, now it seems fine when i drive it
Old Sep 16, 2006 | 09:26 AM
  #18
Do you get DTC 16 as a stored code when you scan it? If so, clear it and see how fast it comes back. If its a "once in a while" thing, it may be fairly normal. If it happens "regularly" its an indication the Opti may be failing, or the harness is corroded.
Old Sep 17, 2006 | 06:51 PM
  #19
Bow94z's Avatar
yea it comes back
DirtyDaveW
Dec 1, 2016 05:37 PM
greenzee28
Mar 26, 2015 09:13 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
brentbrowning01
Dec 3, 2014 10:36 PM
